diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
jcm2555 - Click HERE for Original Thread
audiofan
http://www.blueguitar.org/new/schem/marshall/2550.gif
on the preceding site the is a schematic and something is wrong the plate of the first tube is connected to ground, the same error can be found on many www site probably copy from site to site does somebody know the correct layout?
Centauri
Ignore the plate earth - it should not be there. Also noticed at bottom of phase splitter, 10ohm resistor should go to earth, and there should be connection dot above it (connecting VR7 slider).
Cheers
Page generated in 0.042562961578369 seconds with 17 queries,
spending 0.02501059 doing MySQL queries and 0.01755238 doing PHP things.
Copyright ©1999-2009 diyAudio.com
