diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Sub/amp/receiver question - Click HERE for Original Thread
taylor
I'm not sure this shouldnt be on the SS forum but.. Ive got an old Adcom 10" sub I would like to use for a small HT system. It is a DVC driver w/ a crossover I'll bypass. I also have a Hafer DH200 laying around that is not bridged and would like to use it to power the sub via an A/V receiver. Can I use a y connector from the receiver to split the signal and feed the two channel amp or do I need to bridge the amp like I know I should (I already have two others that are bridged). This is a family room thrasher system so less time/cost = better.
Thanx Taylor
subwo1
Does the subwoofer have a dual voice coil? If not, I see no problem in driving it with only one channel of the amp if you are not going for maximum power output.
Super
Yes, you can use a Y connector. It will be fine as long as each of the voice coils receives the same signal.
Page generated in 0.032627105712891 seconds with 16 queries,
spending 0.01744151 doing MySQL queries and 0.01518559 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
