| fmak |
| Can someone pl explain the differences between SPDIF and ADAT optical for single lightpipe connection? Are they interchangeable and what does it take to convert:confused: |
| rfbrw |
| ADAT is 8ch and up. SPDIF, at least in its IEC60958 mode, is 2ch. |
| dhaen |
ADAT is a multitrack format.
I beleive it sends all tracks down the same pipe, so you'll need a box. But that's what you were asking wasn't it;)
What's in the box....? |
| fmak |
Thanks. Problem is: I want to go the other was ie ADAT output to optical spdif. Any suitable chip?
:confused: |
| rfbrw |
| You will have to make yourself clearer. |
| usekgb |
ADAT is an 8 channel format invented by Alesis to transmit 8 channels of digital audio down a single piece of fiber. They used the TOSLINK connector because it was already readily available and they didn't have to design something new. SPDIF is the Sony/Phillips Digital InterFace. It transmits two channels of digital audio and time code. If you want to connect your system using ADAT, you will need to use an interface box to split the eight channels out to separate jacks. There are a few of them in the pro-audio world to choose from. If I recall, Tascam makes a pretty good one.
Zach |
| Cobra2 |
I have a Fostex Cop-something that takes SP-DIF & ADAT from optical to coax(RCA) or XLR
Arne K |
| fmak |
| quote: | Originally posted by rfbrw
You will have to make yourself clearer. | --------------------------------------------------------------------
I'll try. I have bought an A/D convertor that outputs ADAT or aes/ebu. I would like to convert the ADAT signal to spdif optical/electrical. In prefer to leave the aes/ebu output as is.
:cool: |
| rfbrw |
| quote: | Originally posted by fmak
:cool: |
Assuming your ADAT optical I/F has 8ch, you have three choices.
1. An off-the-shelf solution
2. A diy solution using the Alesis optical rx and 4 SPDIF tx chips.
3. A diy solution using the Alesis optical rx, 1 SPDIF tx chip and a channel pair selector.
For options 2 and 3 the parts needed are few in number and readily available.
BTW what ADC have you got? |
| rfbrw |
Easy to build it may be but it will not do what is required. The COP2 converts optical ADAT or SPDIF to its electrical counterpart.
What fmak appears to need is conversion between optical ADAT and electrical or optical SPDIF and this calls for the demultiplexing of the 8ch optical datastream into 4 distinct channel pairs. |
| Cobra2 |
That is why we have software? :clown:
Arne K |
| rfbrw |
| quote: | Originally posted by Cobra2
Arne K |
Point the way to this amazing software that will convert 8 channels into 2 with no hardware in between. |
| Cobra2 |
Midi++ software, Logic Audio Platinum (I think)+?
-never been a midi-fan myself...
Arne K
Ane somtime ago, I had an ECHO soundcard with breakout box for a lot of channels... |
| rfbrw |
Arne K
To quote a famous tennis player , "You cannot be serious!". |
| Cobra2 |
| quote: | | "You cannot be serious!". |
I never said I was :D , it was just suggestions, have never used the multi-ch. feature myself.
I used however the COP-2 and a "Pro" Spectral A/D & D/A converter along with a PC ca. 10 years ago, (still have some bits & parts).
Sorry if I confused anybody.
Arne K |
| fmak |
Expensive Britain. The COP-2 sells for £99 here and $79 in the US...; nearly half the price. Someone is making a good profit! |
