diyAudio.com diyAudio Forums Archive > Top > Source > Digital
My Kwack clock implementation - Click HERE for Original Thread
Andypairo
First of all I want to thank Elso for sharing his project.
Of course my implementation doesn't claim to be state of the art, since it's made on veroboard without a great experience on HF layout, but I thought it could be nice to share my building experience and to receive a feedback from who has built it (and from Elso, of course!).
I borrowed (again ;) ) a digicam and took a few shots.
Pic 1: the assembly
Andypairo
2nd pic: a closeup of the board
As you can see I used a MAX913 as comparator and also a J310 instead of J309 as JFet.
The crystal comes from Elso so it can't be bad:clown:
Andypairo
Pic 3 output waveform
Not bad at all, considering that for now I only adjusted the duty cycle roughly
Andypairo
Pic 4: voltage at the gate of the JFET.. a good sinewave
Andypairo
Last pic.. voltage at source of Jfet.. can someone explain why the waveform has a bump?
Should I try swapping the fet with another model or I'd better change the value of the source resistor (or what else)?
Cheers
Andrea / waiting for comments
Andypairo
While taking further measurements to get rid of this bump I noticed the extreme sensitivity of the node connected to the source to capacitive loading to ground... I should have realized that before (the cap to gnd is only 39 pF !) but all became clear whan I left out the cap and connected my oscilloscope probe (10x)... I got a nearly perfect sinewave!
Then connected the same probe to the output and.. nothing! The oscillator had stopped working...
Conclusion: the bump is probably due to the capacitance of the probe:smash:
Cheers
Andrea / who enjoys learning from building circuits:D
Elso Kwak
Hello Andrea,
You got decent squarewaves indicating a working clock. The "bumps" you mentioned are not important at all.
One of my first faults was connecting a 1x probe to a CMOS oscillator as it stopped working immediately. Yes ordinary probes have capacitance too.
I am using other kind of parts but I have seen pictures of the KC with all kinds of parts. Here is another one (not by me):cool:
zygibajt
I'm just finishing mine on vero board ,too.Had put it together week ago but waited for J309 to arrive (thanks Elso for J309,i just recived it a couple of hours ago).
I'm just not qiute sure how the pin-out of J309 is and how to put it into circuit.
I assume drain goes to + supply,source to crystal and gate to AD8651 and to ground trought 1Kohm resistor.
Is it correct??
Bartek
Elso Kwak
Is it correct??
Bartek
Hello Bartek,
See this site for pinouts by Yeo :http://www.diyparadise.com/clock.html
It is Drain to supply, Source to 1k and Gate to crystal.:cool:
zygibajt
Thanks a lot.
Maybe i will put some photos tomorrow if I get the camera.
For now I will use it with CDP supply but will build separate this coming week.
Bartek
Andypairo
quote:
Originally posted by Elso Kwak
Hello Andrea,
Hello Elso,
do you think that a separate power supply is worthwhile or i can sticjk with the one of the CDP?
Cheers
Andrea
Elso Kwak
quote:
Originally posted by Andypairo
Hello Elso,
Cheers
Andrea
Hi Andrea,
I tried both but found the raw supply of the player giving better sound. This is a rather unexpected result but I can live with that. Just follow the instructions I have sent you.
:cool:
Andypairo
Thank you, I'll probably install the clock in the following holidays...
Cheers
Andrea
YongHo
HI. Elso Kwak
I wanna make your KWAK-CLOCK-7
But I wanna use different PSU
I think high quality SHUNT REGULATOR will be fine
So I have to design SHUNT REG for KC7
But I dunno how much current needed for Oscillation(J309 and etc..) section. For AD8561(AD8611) section I can refer to Datasheet :confused:
Would you tell me how much current needed at oscillation section(J309) ;)
Sorry for poor English
Merry Christmas !!
krishu
Hello,
thanks to Elso for sharing his knowledge.
I am looking around for the components, j309 seems to be difficult to buy. J310 is no problem here, so can I use this without
any problems?
Can anyone please name the thread where Elso postet the schematic for Elso Kwak 7, I downloaded the schematic, but missed to save the url. I wouzld like to link it at my website.
Thanks to all
Christian.
Page generated in 0.036932945251465 seconds with 17 queries,
spending 0.00672817 doing MySQL queries and 0.03020477 doing PHP things.
Copyright ©1999-2009 diyAudio.com
