diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Bosoz with other amps - Click HERE for Original Thread
kevyjo
This may be a silly question, but thought I would ask. I've looked through the old threads and couldn't really find an answer. Will the BOSOZ work with pretty much any power amp? When I build it I will be using an NAD c370, which the power section is the same as the 270 power amp. Eventually I plan on building amps, but just wanted to make sure it would work in the mean time
wuffwaff
yes it will,:)
as long as the input impedance is large enough for your planned output impedance.
william
kevyjo
The imput impedance of the NAD is 20k ohms
Nelson Pass
One more time:
Both Boz and Sboz are current source outputs, and are
resistively shunted to ground. As a practical matter, for
any given input voltage, they will drive even a short with
the same amount (actually a little less) of distortion.
kevyjo
Honestly, I'm really learning this ee, slowly. Here is another one im sure has been discussed, but I can't seem to find threads on; what are the implications of adding multiple outputs on the bosoz? I could use two, or even three sets of outputs, and want to afford the possiblity of an active crossover in the future
lgreen
Hi, multiple outputs are fine, I just wired mine up this morning, two balanced and two SE outputs on my BOSOZ; everything in parallel. I don't plan on using them all at the same time, but its nice to have options.
You searched? Did you see the discussion here:
http://www.diyaudio.com/forums/show...?threadid=20968
Note my answer for other things to look out for.
kevyjo
No, I'm sorry, I missed that one, thank you.
wuffwaff
Kevyjo,
just make shure that your output caps are big enough. The lower the input impedance of your power amp the higher the -3dB point from the high pass will be.
william
kevyjo
As far as I understand it, the input impedance of the SOZ is only about 5k ohms, if the output capacitance is designed to handle that, Id think it'd do fine with 20k ohms
stefanobilliani
quote:
No , the Son of Zen has the imput impedance YOU will care to use, even higher than 5K. Just choose the resistors you like.
kevyjo
Sorry, I havent gotten that far yet, still working on understanding the shematics of BOSOZ
stefanobilliani
Both SOZ and BOSOZ are differential pairs , nothing more, and they work both in the same way :) so the consideration on input impedance is good for BOSOZ too.
kevyjo
I have yet to order the parts to build my bosoz, so I am open to suggestions; However, I've decided to stick with the specified parts and only change them if I have a reason to; I've decided to go way overboard on the torioid because it has been discussed that oversized toroids seem to have a positive effect on the sound and, it's CHEAPER to do it that way, I figure I might as well!
Page generated in 0.031272888183594 seconds with 17 queries,
spending 0.00809741 doing MySQL queries and 0.02317548 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
