diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Clock speed of Sony 620 650 ES players - Click HERE for Original Thread
Fritz
Does anyone know the clock speed of teh Sony CDP620 or 650ES players? They were built around 1986.
Elso Kwak
quote:
Hi Fritz,
As your Sony was before the introduction of Sony's bitstream converters I believe the frequency is 16.9344MHz.
But you have to locate the crystal anyway if you want to do the clock mod. The crystal looks like a small flattened metallic cylinder. Usually the frequency is printed on it, at least partially.
Hope this helps,
:cool:
Fritz
Hi Elso,
Unfortunately the thing is packed so tight you cant read the side of the crystal so I may have to remove it to read the package. Woud I be removing the crystal anyways for a clock mod. ie is this were an external clock wires in?
THanks
Elso Kwak
Hi Elso,
THanks
Hi Fritz,
Yes, one of the two pads of the crystal is used to connect the clock. Yes the crystal has to be removed anyway.
:cool:
jleaman
Sony CDP620 can a external dac be used on this cd player ? I have one that could maybe be used for something ..
j'
Page generated in 0.1613609790802 seconds with 17 queries,
spending 0.11880326 doing MySQL queries and 0.04255772 doing PHP things.
Copyright ©1999-2009 diyAudio.com
