diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
how to clean fixed frequency sine wave ? - Click HERE for Original Thread
Bernhard
for distortion measurement I like to have a very clean sine of 10kHz.
Is it possible to filter the sine so that undesired distortions are attenuated to nothing ?
Is there a ready-to-build filter somewhere in the net ?
Thanks, Bernhard
My email notification on replies does not work any more :(
AMT-freak
As opposed to other wave forms, a sine wave of 10 kHz does not contain any signal at a frequency other than 10 kHz.
That means, in theory you will get rid of all noise and distortion if you have an ideal band pass filter designed for 10 kHz. In the real world, however, this filter will be far from ideal, but still it will the dominant contributor to the total noise and distortion.
Steven
Use an LC lowpass or bandpass filter with corner or center frequency of 10kHz.
Steven
tschrama
Hi Bernard,
I think you need a high Q double T network or something like that... but I have good results with a diy oscilator (0.004% THD).. it's a simple wienbridge with a 3.5 watt/220 lamp and a NE5534 ... it's at 1KHz, but 10KHz should be possible of course, perhaps even with lower distortion...
Goodluck,
Thijs
PS
You can check the www.sound.au.com for the 'feed-forward' oscilator.. maybe you can improve on it.. I've been wanting to do that for some time now but haven't started yet..
Page generated in 0.026604890823364 seconds with 17 queries,
spending 0.01207399 doing MySQL queries and 0.01453090 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
