diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Parasound D/AC-1000 tweaking - Click HERE for Original Thread
Cobra2
I just got this old DAC in house, and plan to tweak it a bit.
I already have "K" grade DAC chip's, will implement the mandatory receiver-chip filter update, then my way of tube-rolling; swap op-amps.
Maybe a new clock too...
Anybody with experience here? ideas?
Arne K
rfbrw
If the digital filter is the SM5842, Guido Tent has a module that replaces it with the SM5847.
ray
Cobra2
The digital filter is the older SM5813...
Arne K
Cobra2
There also seems to be 2 versions of this DAC, one with Yamaha receiver-chip, and like mine, with CS8412....
Arne K
rfbrw
quote:
Arne K
Any change to that will require more extensive surgery or the construction of a daughter board. The small size of the DF1704 and the SM5847 should make the construction of a daughter board fairly easy. You could also find out if there really is a difference between the DF1700P and the SM5813, the DF1700P being a rebadged SM5813. Lastly you could become a NOSser:darkside: and ditch the filter.
ray.
Cobra2
I have not heard that the DF1700 is the same as SM5813...The NPC is supposed to be better...and pin-compatible...
The idea of a new type for replacement is more interesting, have sent Guido the question already...
Arne K
Cobra2
It seems that the clock is recovered by the CS8412, and then sent to the dig. filter.
Can I just disconnect the output from the CS8412, and "inject" an external clock into the SM5813?
Arne K
rfbrw
You can do that but you might find the SM5813 out of sync with the CS8412. The correct way to do it would be to derive SCLK and FSYNC for the CS8412 from the new 256Fs clock and configure the CS8412 so that SCLK and FSYNC are inputs.
ray.
Cobra2
I thaught so, having looked at other dac's...
But why are you clock-makers not making a clock for implementing when there is none?
I have not the time or parts making a board myself...
Arne K
rfbrw
It is such a simple circuit, they probably think it is not worth the effort.
Cobra2
Anybody care to show me this simple circuit?
Or a link?
Please?
Arne K
rfbrw
256Fs clock in and 64Fs SCLK and Fs FSYNC/LRCLK out with 2x 74HCT163.
Petter
Arne K
What you should be able to do is to place the oscillator at or near the DAC chips (or I guess in your case the digital filter), and feed the same or a compatible division of this master clock to the source.
This way you are slaving the source off from the DAC. The input receiver should unless you are really unlucky find the digital signal from the source and set it up in a synchronized manner.
I believe there was info on the LC Audio site about this sort of connection some years ago. Try both the Danish (www.lcaudio.dk) and the global (www.lcaudio.com) site as I have sometimes been able to get more information out of accessing both sites :)
Feeding a master clock into the input receiver will not work IMVHO since the input receiver can only be slave of one item - and two clocks running separately (one in source, the other in target) will never run close enough over time to enable close synchronization.
Petter
rfbrw
quote:
Petter
MCLK on the CS8412 is strictly an output signal whatever mode you choose. What can be accepted as input signals are SCLK and FSYNC/LRCLK. In this mode data is double buffered to allow a degree of slippage between the incoming SPDIF data and the incoming SCLK and FSYNC which now clock data out.
ray
Petter
True, let me be a bit more precise:
The goal should be to have an accurate master clock at the digital filter and/or DAC chip.
The means I described involve making sure the digital source ("CD Player" for example) is effectively in synch with a master oscillator in the DAC.
Thus, it becomes necessary to disregard (cut the trace) from the regenerated MCLK of the input receiver in an appropriate position (depending on implementation, typically safets at or near DAC/DF). Thus, you are left with regenerated BCLK and L/RCKL and SDATA. Most devices are much less susceptible to jitter on these minor clocks than the master clock for obvious reasons.
... and then, unless you are truly unlucky, you should get automagic synchronization.
Petter
rfbrw
The original post was about modifying a DAC not a source. While you suggestion sounds nice in theory, in practice it effectively ties the DAC to the CD player, not the most flexible approach.
The clocks you dismiss as minor are everything to the PCM63 and its ilk, hence the suggestion to derive new ones to drive the CS8412 and the SM5813 rather than use the clocks derived from the SPDIF datastream, bearing they have to pass through the SM5813 before reaching the PCM63.
ray
Cobra2
Looked at the circuit (counters), I can get these, but I did not fully understand what signals is going in where...
(I need to be spoon-fed with this digital stuff).
Do you mind filling in the blanks?
Arne K
rfbrw
sent a reply via email.
Cobra2
I did not get any mail...seems like the mail-engine is having quirks...
Please try again, to cobra2-at-online-dot-no
Arne K
Petter
quote:
ray
Agree about flexibility
The "minor" clocks could be double-bufferend and passed with the MCLK to clean up jitter.
I don't think "my" recovered "minor" clocks will be any worse than other simple alternatives.
The CS8412 can as noted by others not be driven by external clock. One will have major issues with synchronization of that were possible. An crystal controlled oscillator or a memory based PLL seems more appropriate for such duty.
Petter
rfbrw
Sent first reply using the Diyaudio mail engine. Sent reply directly second time round.
rfbrw
Petter
The CS8412 cannot be driven by an external MCLK as I have already stated. It can, and often is, be driven by an external SCLK and FSYNC\LRCLK. The newly generated SCLK and FSYNC\LRCLK will be cleaner than their recovered counterparts as they will be generated from an oscillator. Perhaps you might consider reading the datasheet for the CS8412.
ray.
Cobra2
Had a upgrade-session today, and...yes it was worth it!
I changed both the CS8412 & SM5813 for these:
http://www.audiotuning.de/english/i...54-digital.html
(CS8414 & DF1704)
It really made a big difference! And it sounds good!
Arne K
Cobra2
The latest version, with a slightly tweaked Rockna analog stage, CS8414 & DF1704:
Arne K
tmblack
Arne K.
Can you give us the details to the mod. I like to be spoon fed too.
Tom
Cobra2
I cleaned the board for analog-stage parts, disabled pin9 from PCM63-K, added 120 ohm on output to gnd, added the Rockna board, http://www.rockna-line.com/diy/output/output.htm .
On this, I changed a couple of caps, to BG, and upgraded the DC-servo-op-amp.
I also tried the D1 I/V - output, but, since the dac gets a bit warm inside, the input-voltage drifted a lot, and I did not like this. (Do not know if it really means much...).
Anyway, the surprice is that the sonic signature on Rocna and D1 are very similar, or they are very transparent.
Arne K
jean-paul
Nope, DF1700 and NPC5813 are 100% the same. DF1700 is a rebadged NPC chip.
rfbrw
Either you like think very carefully before you reply or things are exceedingly quiet in Holland this morning.
jean-paul
I do not understand the sentence you're saying. Just reread this thread after having had a notification of the most recent post. I used these parts a lot in the past and can confirm they're the same. No more no less.
edit: ha ha , I see what you mean now. The post was from 2003. Slow reply indeed ;) And also a quiet morning, when I posted I had my eyes still half closed.
cartman
OFF
Hi Guys,
I'm after the digital upgrade of my Parasound DAC, but now, I'd like to change the OPAs to betters in analog stage...
Please advice...
Many thanks in advance! :)
ON
Cobra2
Get rid off ALL opamps, and add a (PassLabs) D1 analog stage instead!
Arne K
cartman
my DAC is the type 1500 with balanced out..
This method could works in balanced mode?
thx!
intense-tavda
Hi Arne!
I got a parasound dac1500 and want to make a Pass D1 output stage on it. But I have to replace a part of the board. Can you tell me what I have to do? Or where should I begin? I know this post is 2,5 years old, but I still have the idea I can make the 1500 to todays standard! Is this right? Teake
Page generated in 0.071990966796875 seconds with 17 queries,
spending 0.01439977 doing MySQL queries and 0.05759120 doing PHP things.
Copyright ©1999-2009 diyAudio.com
