diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Rectifiers, DC Supplies, Regulators and the like - Click HERE for Original Thread
kimwong
Hello Folks
Don't know if this is the right place to put this, so hope this does not annoy any-one.
Anyway, I have a PSU for my turnatable, a Pink Triangle Anniversay which has a DC motor. PT used to be able to upgrade to run the TT from lead acid batteries, but have now ceased trading.
The lay out of the standard PSU is 18V AC into a bridge rectifier, a capacitor and then to a voltage regulator and associated resistors which seems to have an output of about 2.2 - 2.5V DC.
Is there ANY problem with using a DC source through the rectifier, as this seems to be the easiest way to convert the PSU to a battery PSU.
My idea is to connect a 12V lead acid battery to where the AC would nornally go in, minding that I have it connected correctly because I might blow the capacitor otherwise.
Also the regulator is an LM317T. I have read that there may be much better ones around. Can anyone suggest?
www.paulhynesdesign.co.uk have a replacement regulator and board and I wondered if anyone out there might have an idea as to what it is and would I have to change the resistors as well.
Many thanks in advance for your help
Kim
Page generated in 0.016196966171265 seconds with 17 queries,
spending 0.00577116 doing MySQL queries and 0.01042581 doing PHP things.
Copyright ©1999-2009 diyAudio.com
