| ACD |
Anyone who knows the pin configuration for the Sanyo 2SD438 and 2SB560 btj transistors??
Sanyo who makes them doesn´t have any specs for these transistors?????
Thanks in advance |
| Jocko Homo |
E-C-B.
I have some limited data on them.
Jocko |
| ACD |
Thanks Jocko!
Is that seen from the front??? |
| Jocko Homo |
Yes.
Almost all small signal types from J. A. Pan, Inc. are that configuration.
Any other questions?
Jocko |
| Jocko Homo |
What is your application?
Jocko |
| ACD |
| I have had them laying around for some time, and now I can use them as drivers in a small Onix amplifier... |
| Jocko Homo |
Probably will owrk fine, if you have them. I usually use 2SA1145 & 2SC2702 there, but only because I have lots to use. I like the Snayo parts in PSU application. Big packeage to help get rid of all the heat in my designs.
Jocko |
| ACD |
yes...
I'm replacing some ZTX653/753 which is the original in the Onix |
| Jocko Homo |
Don't have a Zetex catalog handy, but.....they make some good transistors. The ones you refer to may have limited dissapation, though.......
Jocko |
| ACD |
| Overall specifications are the same, however the 2xx have a larger casing ;) |
