diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
High voltage (120-180V) output drivers - Click HERE for Original Thread
PanzerLord
Any good suggestions for >120V 10-40W BJT drivers (preferebly TO-192 case, low input capacitance)?
sam9
Thats a lot of wats fot to-92. Try Zetex "super e-line" series. maybe something there. There such a thing as a to-92 heatsink - maybe that should be investigated.
PanzerLord
¤%&"%¤/((¤, I meant of course TO-126 case, I`m all messed up, sorry, have been sitting up for 24 hours!:dead:
K-amps
I love the ones Adcom uses in the smaller amps.
They are Sanken devices 2sa1668 and 2sc4382(?) pair.
Hfe is 60 min to 320 I think . 200vce and 25w.
They sound very nice.
Easyamp
Try the 2sd669~2sd49 combo. I always try to use these in the voltage gain stage.
Easyamp
oops, I meant 2sd669~2sd649
sam9
You could also try 2sa1220/2sc2690. Hard to find but try www.matchaknob.com. I think they have them cheap. These seem to be slight upgrades to 2sd669/2sd649.
EchoWars
quote:
The 'A' varients are rated at 160V....
Indeed, these are some of my favorite transistors. Tougher than a lot of TO-220's.
Easyamp...you got a source for these? They seem to be getting more and more of a PITA to find.
Easyamp
Your right they are hard to find, last time I ordered them I think I got them from Newark electronics but I can't remember.
I just went out and looked at the major suppliers and I didn't see any but I think seal electronics might sell matched pairs.
You might have to go bd139~bd140. They are in my auditory opinion close to the 2sd669~2sb649 pair and they are a lot easier to get.
I've never used
2sa1220/2sc2690 before but they look good on paper and appear to be easy to get.
Good luck
ppl
I use the BD139/BD140 hower the 2SA1220 is available from
http://www.fairchildsemi.com/ds/KS%2FKSA1220.pdf
I have also had great luck with these
http://www.onsemi.com/pub/Collateral/MJE243-D.PDF
Almost forget some i have used in a Dimond buffer however meet your specs are 2SA1358
http://www.semicon.toshiba.co.jp/td...8_datasheet.pdf
complements 2SC3421-Y http://www.semicon.toshiba.co.jp/td...1_datasheet.pdf
wrenchone
Depending on the amount of power dissipated. I use 2SA965/2SC2235 (TO-92L package, 0.9W rating, Toshiba), or 2SA1535A/2SC3944A (Panasonic, TO-220 fullpack). You can get the Toshiba devices from Match-a-Knob, and Digi-Key stocks the Panasonics.
Easyamp
Well it's been a while but this post seems have surfaced.
Either everybody was being nice and just thought I meant 2sd669~2sb649 or no one noticed my error, it's not 2sd669~2sd649 it's 2sd669~2sb649. Their is a however a 2sd649 and it's not the comp to the 2sd669.
I haven't been able to find a good source for these gem's other than a few over priced dealers, anybody no of one?
Enzo
I think they meant the 2SD669 and 2SB649, not 2SD649.
Similar pair is 2SC3117 and 2SA1249.
ANy reason not to use TO220s? I much prefer them. I use the 2SC3298/2SA1306 pair a lot. Used in a number of pro audio products. There are others.
Enzo
MCM lists your 669/649 pair at less than a buck each. How cheap you need them? Cheaper than my TO220s.
Jennice
... or what about 2SC2238 / 2SA968A pair ?
Jennice
ppl
the ML#20.5 i belive uses the to220 MJE15030 and MJE15031 as the Vas and CS for it, i use these for driver transistors one of best sounding TO220 8 amp drivers i have found in spite of the 30 MHZ Ft. thanks for the pannasonic tip i have been looking for a set of outs for a headphone amp in the TO126 case and so far the MJE243 sound the most musical in that stage. BTW and sugestions in an ideal ICq for +/- 10 volts and Re=4.7 ohm RL=32-300 ohms. empiricaly i found a minmum of 10 mA and sweet spot is about 25 mA. and 3,5 mA on the 2N5088/5087. what do you guys think?
K-amps
quote:
PPL if you liked the 15030/31, you need to try the 15034/35. They are sweeter and have better bass slam.
:devilr:
ppl
The MJE1503XX series seams to be expanding alot. i have some MJE15032 & MJE15033 do you think, these would be more dynamic than the 15030/31 driving a 24 ohm load with +/- 20 volts. im looking at transistors for headphone amp use and i presently use BD139/140. I was thinking the MJE15032 & MJE15033
K-amps
My guess is the 32 is closer to the 34 and Better than the 30. The 32 and 34 both have same hfe ranges but the 34 is better for hi-volt apps while the 32 has twice the Ic rating at a lesser vce.
By the way for headphones, I have heard nice things about the 2sd669/2sb649's but have not tested them personally.
Cheers!
ppl
one thing i noticed is these 33&34 versions are high voltage type and i suspect Ft would be lower?
K-amps
If I remember correctly fT of both is 30Mhz and the hfe of both is 50 minimum.
The 15030/31 has inferior values than the 2/3/4/5
cunningham
I know that this thread is labled high voltage.
But, I would like to get some feedback on 2N5684/2N5685. Didn't want to make a whole new thread for this. These are something like 80V max, but are quite hefty when it comes to current. This device as I under stand can conduct 50A:att'n: I was wondering what the maximum LINEAR operating current is. I am estimating at or around 9-10A. Does anyone have any data sheets for these devices? (cross referenced to ECG 29 and ECG 30). Beta is around 15-20
Thinking of making a hi power sub amp, Hee Hee.....Thinking class G. :cool:
jcx
...and so far the MJE243 sound the most musical in that stage.
would that be "classic" or "new"
http://www.onsemi.com/pub/docs/pcn/13135.pdf
i find it interesting the product change notice assures no parameter changes, how do capacitance and transient/ max thermal parameters not change with die shrink?
Easyamp
I use mje243/253 as vas and drivers and they seem to work well and for only $.38. The 100v vce rating is very padded. In my vce tester, which is a 340v (originaly 170v) 25ua supply I recently built to find an unknown transistor's vce, I found that transistors are rated for the worst possible vce. I have a 130v 2n3906 while most were 50 or so.
I have 30 something pairs of mje243/253 and the ones tested were all much above there 100v rating more like 160v.
I don't know exactly what this means but I did use a few controll transistors and found most would go 5 - 10% higher then there rated vce so whatever results I get I just subtract 10%.
The tester is an up down 120v 240v transformer rectified, with a 25ua 2n6517 ccs load.
Cheers
AndrewT
can someone tell us what circuit Easyamp used to test his transistors without destroying them?
And how to use/interpret the results?
quasi
I might be simple, but I use MJE340 /350's almost all the time. Cheap and available almost everywhere.
And they're tough little buggers.
Cheers
Q
john_ellis
Hi all
The BD139/140's are good for up to 100V but not higher.
The best I've used so far for higher rails are the 160V 2SA968/2SC2268. These were Toshiba's originally, but are now supplied by Magnatec, available from RS. Last time I saw RS description still had Toshiba listed as the manufacturer. Must let them know this is wrong!
Magnatec appear to make "close equivalents". From my knowledge of the fab company I would be surprised if they have not done a good job at providing a good match to the Toshiba's. Have not got a Magnatec data sheet, but frequency response is similar to BD139/140 as measured at 1 MHz (this doesn't say much though).
cheers
John
Eva
A pair of complementary high voltage drivers that deserve mention are 2SA1837 and 2SC4793.
max. Vce=230V
max. Ic=1A (very linear up to 0.3A)
Ft=70/100Mhz (PNP/NPN)
TO-220 plastic case
Output capacitance=30/20pf (PNP/NPN Vcb=10V F=1Mhz)
ChocoHolic
...recently started a personal love story with the 2SA1930 & 2SC5171 from Toshiba.
180V/2A/20W
Ft=200MHz
Cob: 16pF(NPN), 26pF(PNP)
Typical gain around 200
Fully isolated TO220
I am not sure if you still find a source...
If yes, then try these devices!
sajti
2SC2911/2SA1209 from Sanyo, with TO-126 packages, and very very low capacitances. Nice, for VAS, and predrivers too
sajti
destroyer X
Related the BD139, a very good unit, was used for many years as drivers to Radio Frequency transmitters operating up to 30 Megahertz.
I know about people that have used it to 100 Megahertz FM transmitters too...of course it will loose power in that frequency.
Till 100 Volts it is very good.
regards,
Carlos
Page generated in 0.0660080909729 seconds with 17 queries,
spending 0.01326561 doing MySQL queries and 0.05274248 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
