| K-amps |
This may be a bad idea... but has anyone tried paralelling bridge rectifiers? :cannotbe:
Not necessarily for more current but for reducing the impedence and therefore maybe the voltage drop....
My concerns are around RF, current hogging (fix with 0.05 ohm power resistor?) :rolleyes:
Any thoughts from the gurus?
thanks! |
| millwood |
| quote: | Originally posted by K-amps
Not necessarily for more current but for reducing the impedence and therefore maybe the voltage drop.... |
paralleling rectifiers will NOT reduce their voltage drop (well, it does but just too insignificant as Vf does drop a little with Ic).
balancing the two can be very tricky.
if forward voltage is your goal, try schottky rectifiers. if current is your goal, get a beefier rectifier. |
| K-amps |
| Probably not worth the effort right? |
