diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Introductions
Hello from Germany - Click HERE for Original Thread
Marc´o Polo
Hello,
my name is Marco and I live in the north of Germany next to the danish border. I´m a guest in this forum for about 2 years.
I´m an audio and diyaudio freak and I´m currently working on several audio projects to renew my audio system:
Tube gear:
Mono Poweramps based on the Audionote Gakuon. All parts are ready, and I´m currently working on the chassis construction.
Same with the M10 preamplifier.
Solid state:
Developing a poweramp with bridged and parallel lm 3886.
Preamplifier : I have collected a lot of nice audiophile parts during the last years and currently I´m doing a lot of simulation
and testing to find the optimal solution.
Speaker:
Almost finished : 4 way speaker with ATC sb100/375 , sb75/234,
sm75-150s and a scanspeak RR 9700
I hope to find a lot of new knowledge as a member of this forum, and maybe I can give some usefull information.
dkxdn
Hi Marc
Can you explain more about your speakers: crossover, cabinet ...
Iam also using the ATC Dome and I LOVE THAT DOME.
Marc´o Polo
Hi ,
all the speakers, except the 15" are mounted in a flat panel (open baffle) made with MDF. This panel is covered with leather (same style as the Sonus Faber Amati´s) This panel will be mounted in another baffle made with MDF and cherry wood. This baffle is about 5´high and 1,5´wide. The 10" is mounted above the sm75/150s which is mounted above the SS 9700RR.
The 15" is mounted in a closed cabinet with about 80l and heavy bracing. This box is made from MDF and and covered with some cherry veneer and some massiv cherry wood.
The crossover will be mounted on top of the bass cabinet. I have added some extra space inside the box. All parts for the crossover are from Jensen (foil inductors, capacitors) and Mundorf (zero ohm coil for bass and "supreme" and tin foil caps).
The work for the crossover is still in progress. I have started with some schematics from the internet and I will play with the values and do some measurements if the box is placed in it´s final position.
Marco
dkxdn
Your speakers is much like Lukasz Fikus: Project 10 http://www.kingston.neostrada.pl/
You can read about my work at: http://home10.inet.tele.dk/dion/
Iam now getting the Behringer DCX2496 integreted
Marc´o Polo
Yes, you are right I got a lot of influences from Lukasz Website.
I think it is a wonderful starting point for this kind of speaker, and I like his philosophy about loudspeakers design.
Page generated in 0.027295112609863 seconds with 17 queries,
spending 0.00926638 doing MySQL queries and 0.01802874 doing PHP things.
Please support our sponsor.
