diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph 5 Monobloc Or Not - Click HERE for Original Thread
george a
Hi All
I am soon to commence (i hope)my Aleph 5's but am unsure as to which way to go with power supply.
i have the following bits
4 off 80000uF caps + 2 chokes
2 off Tranformers each 25-0-25 @ 50A
The dilemna, do I go single supply with total 160000uF per rail (320000Uf total) with either 1 transformer or 2 in parallel?
This would also involve use of chokes between caps( for a pi? filter??).
or
dual mon supply with i transformer per channel and 80000uF caps per rail for a total of 160000uf per amp. - no chokes though
Any comments welcome..
Thanks in advance
george a
Or I could do this to power subs as well (plus P1.7 Preamp)....
george a
actually -correct wiring of the diodes and caps would work ebven betterer! ....doh!
I'm sure you all get the idea..
Taco
The production Aleph's don't use a coil in the powersupply. So I would suggest to use 1 trafo+ 160.000 uF a channel. I would not recommend to power also your preamp from the same supply, The P1.7 needs a 60 Volts (dual 30V secundair for your trannies) I don't see how you want to get this wiht transformers with 25V secundair voltage.
george a
Taco
thanks for reply
if you at posted schematic you will see wher i'll get higher voltage from, which can then be regulated for the P1.7.
Taco
Now I see what you'r doing :P, this only works with 1 common supply but don't you get an uneven load on those trannies. Don't know of this matters.
MikeW
It depends on how you are going to cool them. If they are built in as stereo you will not be able to lift them unless there are fans. The stereo A-30 that I built with the R-theta heatsinks is 72 pounds. It has a 20 degrees rise. The mono blocks will be more work but easier to move.
george a
Taco
Transformers each rated at 2.5kva , preamp load probably.
not an issue
I beleive alpeh 5 draw constant current and hopeffuly wont react with supply to preamp.
Subs supply (feeding Hafler dh200 clone) may be a different story though. if this proves a problem then i have a spare Hafler to use as a stand alone bass amp.
Am just trying to get the poewr for the preamp from somewhere without having to by another transformer.
Also trying to keep things a bit more compact
george a
MikeW
I am thinking of fan cooling + 2 boxes -
one for Power supply and one for power amp.
Will probably still weigh in at about 70 pounds anyway....
Transformers currently power hafler clone and I can carry it short distances only.
I will probably also need some hefty cables for linking the 2 boxes- may put half of caps in amp box...(160000uF)
Taco
quote:
Originally posted by george a
MikeW
It's a good idea to put some of the filtercaps in your ampcase. And now realizing that you use 2,5kVa trannies I think it's no problem at all using 1 supply for both.
roddyama
Hi All
or
Thanks in advance
The transformers are huge. One is 3X more then what is safe for both channels of an Aleph5. But, with what you have listed, I would suggest a single CLC power supply for both channels
Personally, I would take a different approach by adding 4 more caps (maybe half as large) and 2 more coils, but still using only one of transformers.
BTW, those transformers would be great for a high powered AlephX monoblocks (~200wpc).
This is not a good idea. You what your preamp power supply to be as clean as possible.
george a
Roddyama
you wrote
"One is 3X more then what is safe for both channels of an Aleph5"
Can you please explain what you mean please ...
How can too big a transformer be unsafe.
BTW these transformer have been powering a Hafler 200 clone for the past 15 years- without a single problem..
With respect to P1.7 Supply i intend to regulate supply to it..
Thanks in advance.
roddyama
Roddyama
Thanks in advance.
Hi George,
I didn't mean to imply that you would be unsafe. Quite the opposite, you would be waring a belt, a rope, and suspenders. 800VA is a good safe transformer size for a stereo Aleph5. 2.5kVA is 3X safer,... if there is such a thing.;)
Page generated in 0.051448106765747 seconds with 17 queries,
spending 0.01959395 doing MySQL queries and 0.03185415 doing PHP things.
Copyright ©1999-2009 diyAudio.com
