diyAudio.com diyAudio Forums Archive > Top > Source > Digital
DACKit complete, but a few issues!! - Click HERE for Original Thread
jonclancy
Hi All (and hopefully Scott is reading, too!!),
well, I have just finished my DACKit and have fired it up using a 12v 7.5 ah gel battery. The batt had 11.5V when we started.
I was sad to hear lots of fuzz, and the music very quiet in the background. Our houseguest re-connected everything and turned on the system again when I was out of the room. Much excitement as music filled the room! Hurrah! :D
Anyway, I left the CD on overnight to burn the dac in. This morning, the fuzz was back. Hmm. :xeye:
However, the batt voltage was down at 6.5!!! :eek: I recharged it today, and it was steady at 13-ish. OK, now to re-connect.
Still fuzz, then I remembered something about the order of when to switch on the source and the dac. I had the CD on and then powered up the dac. It worked:) !
Happy that I thought I had solved the problem, we listened to some Annie Lennox (Album Bare, track 5 "Wonderful"). No problem here, sounded very nice. Then, only occasionally, the sound would drop out. :confused: Once the loud part of the song kicked in, the system went dead. Hmm. :cannotbe:
I turned everything off, back on, and the fuzz had returned.
Does anyone have any ideas? I was as careful as I could when I assembled the dac, but I think I have missed something here.....
Anyway, here are some pics. This is my first project, and it will not be complete until I can enjoy those sounds.
BTW, compenents are 0.1% resistors, BG and Wima caps, teflon coated silver wire etc etc.
CHEERS
Jon
jonclancy
Here is the open case......
Jon
jonclancy
I was hoping my work would be neat enough.......
Jon
jean-paul
Are you sure you soldered the electrolyics in the right way ?? I don't see that you made errors with grounding but it is not always clear what one sees on a picture. to my eyes the DAC looks OK.
Did you double-check the resistor values and did you measure as well ? Did you doublecheck solder joints ? Did you measure the voltages at the DAC chip and receiver ? I had once trouble with dropouts caused by too large film caps at the input of the CS8412 receiver. I also read once that a forum member used the 7808/9 for the receiver and the 7805 for the DAC chip ...
Maybe it is wise to mail Scott himself for support !?!?! Although I never bought anything from him he always helped me with things I wanted to know.
jonclancy
Hi JP,
I will check all the joints etc. The resistors have the values written on them, so I did not bother to measure them. However, I have not checked the voltages at the dac and receiver. I have a multimeter, so I'll give it a go tomorrow.
The film cap sizes are within the ranges specified, but I was experiencing drop-out, so I will have another look at them.
I soldered in the electros with the short leg as negative. Some were NP, but the polar ones had a gold "-" vertically on the side.
I'm glad you think it looks ok though - I'm really pleased with it (apart from the glitches!!)
Thanks for your thoughts!!:)
Jon
jonclancy
I forgot to mention that the LEDs are not installed as I coudn't make up my mind which one to specify.
Of course I want blue ;) but when I look at the LEDs available and work out the 330R resistors into the equasion in the Maplin cataloge, the figires don't quite add up (or I will get a very soft blue???).
I am learning tons as I am going thought this!! :D
Jon
jean-paul
Jon, please check current draw of those fancy blue LED's first ! Not being one with much experience with blue LED's ( it is more original to use plain read and green ones nowadays with every pc or amp having blue LED's :D )
I recall they have a Uf of 4V and draw more current than their red/yellow/green/orange collegues. AFAIK the LED's on DACkit are fed directly from the CS8412 that has a current limit. Please check CS8412's datasheet for that value. You might have a chance that a switching transistor has to be added.
I leave the googling for the blue LED current draw and the maximum current output of the CS8412 for you.
The series resistance is calculated as follows: R = ( Ubat - Uf ) / I led. I led is the desired current through the LED of course. Ubat is 5V and Uf is the forward voltage of the LED in question and depends on the colour of the LED.
Still waiting for fancy purple LED's ....
jonclancy
Now there's a thought!!
Maplin do an Ultra-Violet LED - new product.
That could look good with a bit of engraved, painted lettering on a thick Acrylic fascia!!:D
I'll report back with my voltage readings tomorrow eve.:hot:
Cheers!
Jon
scottnixon
fuzzy frizzy huh? Double check PLL filter values, 1k and 0.047 should work for sure. Then shorten and untwist and separate the input lead to the receiver. If you need the length, use a miniature 75 ohm coax, but it's bad form to twist that pair. Good lookin' dac there, I'd say.
scottnixon
The receiver goes low to trigger and the LED anode is pulled high through the +5 rail. Most any normal (ie: non-super brite or high current) LED is fine. I use blue, green, red whatever and never have had an issue, unless I doubled up on them.
jean-paul
With 10 mA as a maximum output current it doesn't hurt to be a little cautious ;)
scottnixon
I would re-route the DC power cabling to NOT be under the pcb. Just follow chassis wall around the 'output' side of the pcb. Clocks and digital buss could possibly be messin' with the supply feed. Just good housekeeping
jonclancy
Scott and JP, thanks very much for your comments.
I've got to rush off to work now, but will be acting on your advice this evening (well, the bits that don't require a soldering iron - didn't bring one with me:clown: !!).
Cheers
Jon
jean-paul
Don't know if the PCB permits it without having to drill new holes but turning the board a quarter to the right maybe will solve the too long digital cable crossing the supplylines ( I would shorten them anyhow ). You will have to change the SPDIF and the powerconnector if you do this. So SPDIF will be in the middle if you understand what I mean.
I always use thin 75 Ohm coax for the input. Less possible problems and electrically more correct. It is called RG-175 ( 3 mm diameter and flexible ).
Reroute the supplylines at the opposite side of the digital input just as Scott suggested.
A last tip: do a search here for the Monkeysect filter. Your DAC will sound even better.
Have fun with your DAC !
jonclancy
Hi JP, Scott,
I have done some measurments and have some (unexpected) results.
Battery voltage = 12.88
Input at the L7808CV = 12.85
Output from L7808CV = 9.94 (yup, 9.94!!) :eek:
Voltage across 1543 pins 5/4 = 9.94
Input at the L78S05CV = 12.83
Output from L78S05CV = 4.98
CS8412 at pins 7 and 22 = 4.98
I have no digital source with me to do any further measurments or tests. I suspect that my IC regulator is not doing the business (by nearly 2 volts)!! :rolleyes:
I am going to order some RG175 from Farnell, and will replace the 8v ic. Do you have any recommendations - i.e. performance wise?? It appears that the 5v part is behaving itself. ;) If I have damaged the TDA (max 8v) then I have a spare - but I am hoping I got away with it.......
This overvoltage might explain the dropping of the signal when Annie Lennox was getting loud!!
More news as it comes........
Jon :)
jean-paul
Now that explains a lot ! That poor TDA must have got the fever ...
It was surely clipping. You see that measuring is the first thing to do even when things *seem* OK.
jonclancy
Hi JP,
I now appreciate that!! :rolleyes:
I wonder if getting dodgy ICs is common?? Or is my assumption that the IC was faulty flawed? Perhaps I damaged it with prolonged heat while soldering it in.
Anyway, I'm going to look for a less :hot: replacement!!
Cheers
Jon
PS Do you mean RG-179?
jonclancy
.........I have ordered some more VRegs (and some Pana FCs for my AMPKit pcbs, LEDs - a special variety - bezels, coax, etc!!;)
Just to make sure that I am not going to kill the ICs, is this ok?
To test a VReg before installation, put 12V from the battery through the input and gnd (I am thinking of taping wires, but leaving some ground exposed), and then measure gnd and output? This will be on the bench, before installation (don't want the same dodgy output voltage as before!!:hot: ).
Apart from that, this Friday is DACKit day :D and the weekend will have some thought towards the four LM3875 monoblocks that I am planning!!! :eek:
A little bit of knowledge is a dangerous thing....;)
0100.
Bed.
:wave2:
jonclancy
Hi All,
here is an update - the bottom line is that I still have mightily distorted output, at very low power. :bawling:
However, I have:
tested the 8v reg - It was messing about at nearly 10v, but now, for some bizarre reason, it is steady at 8v when I measure it (and I've been measuring it lots!!).
Replaced the twisted-pair input for some 75 ohm coax (not the thin stuff that I couldn't get - mad the job a little challenging!!).
Rewired the outputs - shorter (though all equal lengths) and better routing.
Re-routed the pwr supply wires to the case wall on the output side.
Finally, :xeye: I have replaced the 1543 with a spare.
Well, I had high hopes when I went into testing, but I was still in the same boat!!! :cannotbe:
I would really appreciate any other thoughts on what the problem could be. ;)
I think that the next stage would be to re-solder any joints on the pcb that aren't chromium bright!!
I am very pleased with the case-mods (incl feet that were originally stainless wine bottle stoppers from Sainsburys!! :cool: )
At least I am learning how to use my multimeter!!;)
Here is a pic of the Work In Progress:
Cheers
Jon
jonclancy
Here is the rig undergoing testing on the ARCAM system.
jonclancy
..really would be gratefully accepted!!!
Jon
scottnixon
The spacing on the board is .4 inch and Holco 1/4 w are kinda fragile about tight bends on their end caps, so there is a possiblity there is one resistor damaged. check the IV and Vref R for value. The Vref and both IV most be to spec and the values I sent, any substitution will likely not perform properly. There is about a 30 ohm range for lowest distortion on the Vref above or below the spec'd value. 2.49 needs 1.37 :)
bequerel
I have built a DacKit, and it sounds extremely good, regardless of price. When building the kit I noticed that the kit used a bare wire to connect two points under the receiver. If you use this bare wire, check that it does not make a short with some of the traces it crosses. It is extremly close to some of them!!
jonclancy
Hi Scott, Bequerel,
Thanks!! This will give me some more ideas to check when I get my hands on my DACKit tomorrow.
I'll check the single wire link (which was the first item to be installed) the best I can, as it's under the receiver, but I will measure the resistance to see if there is a dry joint. Likewise the resisitors. My plan is to select the next point downstream / upstream from each lead so I am checking the integrity of both the solder joints as well as whether there is any lead damage.
I did use a mix of Holco H8s and RC55Ys. Although I used a lead forming tool to try and bend the leads once (and quite near to the resistor body), on more than one occasion I had to redo the bend (I wanted the markings all facing up - a little sad, eh!:angel: ).
Finally, I will double check that the IV and VRef Resistors are 2.49 and 1.37. I did order these parts specifically from Farnells after a bit of a supply hiccup, but, like all the resistors, I trusted that they did what they said on the body!!!
I'll get my multimeter!!:)
Thanks very much - Although it's been a bit of a challenge, I am learning a vast amount about this hobby from only one project!!!:D
Cheers
Jon
ryssen
Do you have a schema for your DAC?
jonclancy
A very similar DAC scema is available at
http://www.geocities.com/rjm003.geo...io/diy_dac.html
HTH
Jon
jonclancy
Scott, JP, Bequerel,
well, all advice taken and acted upon.
Success!!!:D
It was a dodgy joint on the 1.37K VRef resistor. I was measuring across the components to check the values, then from the next point along the circuit to check the joints. The 2.49K parts were testing fine with the negative probe on the ground track. The 1.37 wouldn't register. A quick bit of work with the Soldamop (and it was horrible stuff I mopped up!! :eek: ) and then a resolder with the Draper 60/40 (I started off trying to use the silver loaded stuff - I will use it on the gold connectors and silver wire in future, but not on the main board - What a PITA!!:angel: ).
Multimeter read spot on!!:) Plugged the bare board in and, hurrah!, it works!:D
Interestingly, the output is so powerful that the Arcam only needs to be cracked-open to get a decent sound. There was a bit of background hiss, but selecting "direct" to bypass the tone controls sorted most of this out.
Well, as you can guess, I am really pleased with the result.
A big thank you for all the advice and support. Especially to Scott who was generous with his advice even before I had started the project.
Well, eveyone is going to get a big surprise tomorrow!!:D
Thanks again!!
Jon:cool:
li_gangyi
so it was just a resistor huh...seems like there are some [problems we keep missing...
jonclancy
But not next time!!!
Hopefully!
:rolleyes:
Jon
Andypairo
Glad to see that you succeeded in fixing it!
How does it sound?
Cheers
Andrea
jonclancy
Hi Andrea,
First listening seems to be fast, but with more emphasis on the mids and lows than I was expecting. The deatail is there, but is more in the background than the foreground. The soundstage does seem deep and well-defined. Of course, there is plenty of running in to do, and I expect the sound to change through the process. We'll be conducting some AB testing when it has had a chance to settle down. The output level appeared to be very high at first - had the amp turned way down for a quiet-ish volume - but this has now settled down.
There is a background hiss that was very much attenuated when I defeated the tone controls on the Arcam amp (with the "Direct" switch). Overall, it sounds very nice :) and I am combing the CD collection for some decent recordings to try out (it's amazing how poor some production is nowadays!!):xeye:
I am delighted that I can top up the battery using the CSI Airflow battery conditioner I used to use when I had an old classic car. This has been sat in the box for a couple of years and now has a decent job to do (thank goodnes - it wasn't cheap!!).
The bottom line is that this has been a really SUCCESSFUL project. I have had plenty of questions along the way, and a problem to solve that was caused by my inexperience with a soldering iron!!;) The good news is that the DAC is working well, but the best news was that I have learned a whole load of stuff in the process!!!:D
I recommend the DacKit if you haven't built one already!:)
Cheers
Jon
jonclancy
In fact, just listening to Annie Lennox' new disc "Bare" and it is sounding better all the time. Detail is appearing and there is plenty of weight in the bass.
I wonder what it will sound like after a couple of hundred hours burn in??? :cool:
Jon
Andypairo
quote:
Originally posted by jonclancy
Hi Andrea,
--zip--
Cheers
Jon
Well, the "background" detail is about the same impression I had with mine (I've actually built one, based on Doede's DDDAC).
For now I only tested it at 7.5V but I expect things to change playing with Vcc...
Cheers
Andrea
jonclancy
Are you going up or down on the Vcc?
Jon
Andypairo
I'll try both and then will let my ears choose;)
Cheers
Andrea
PS I just borrowed a digicam, shortly I'll post some shots of my setup.
Page generated in 0.073683977127075 seconds with 17 queries,
spending 0.00820732 doing MySQL queries and 0.06547666 doing PHP things.
Please support our sponsor.
