| palesha |
I hv one hometheater from china having TDA1006 faulty. I am not able to get the datasheet of the same. Kindly help me in the matter. It is like TDA 2030.
MP |
| Netlist |
Are you sure it's a TDA1006.
TDA1006 is not at all like TDA2030.
/Hugo :) |
| palesha |
That is what printed on IC. Further i found that many chinese mfg.'s r using the same IC. u can confirm on net. This same thing is puzzling me. Now i hv downloaded YD1006 datasheet.
MP |
| Netlist |
:scratch:
TDA1006 is a motor speed controller IC.
TDA2030 and YD1006 are 18W power amplifiers.
/Hugo :) |
| WEALSPEAKER |
| please tell me what i can replace for bad yd1006 ? is there any equivalent ic |
| Paswa |
| eqivalent of YD1006 is TDA2030 from ST, both r 18w audio amp. |
| WEALSPEAKER |
| are you sure yd1006 equivalent to the tda2030 i mean regarding the pin configuration and the performance ??? i know they both 18 watt but can they be interchangeable if one another ? |
| Paswa |
| friend, please wait a while, I'll write u next day after final confirmation.. |
| WEALSPEAKER |
pawsa your reply take more than expected any way thank you
the speaker is lying on the bench waiting for repair please forum members if any one can help me i have a speaker that has tda1006 burn can i replace it with tda2030 or they are not interchangeable |
| Paswa |
ok ok, i was just a little busy 4 me exam.
1>YD1006 and TDA2030 are same in pin config. you can also check it in TDA2030 datasheet here
The YD1006 app config here, it is same to the TDA2030, pls check it again |
| WEALSPEAKER |
thank you paswa i refer to the diagrams i find them identical in this parameters they have the same out put currnet and the vcc values the same power the same pin configuration the allowable swing in the input values so primirly they are the same
thank you for help paswa |
