diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
OPA541AP Subwoofer amp - Click HERE for Original Thread
Alcaid
Hi!
Can someone help me to build a subwoofer amp with the OPA541 chip. If it is supposed to be 4ohm stable, do I need to do a parallell setup, or maybe a bridged parallell?
How many watts will it then push out?
Anyone got schematics for these setups with the OPA541?
OPA541 or OPA549 for a sub amp? (or another IC is better?)
Thanks for any answers! :)
Alcaid
Can someone help?
Anyone who have parallelled the OPA541?
How many watts can it give into 4ohm?
Mad_K
build something like this.
you can use the opa541am/ap, just put a link from after Rout on each chip back to pin 1/8 on the opa541am/ap. it will give you 200W in 4 ohms ;)
http://www.national.com/an/AN/AN-1192.pdf
edit: you can also use lm3875/3886/opa549 ;)
Alcaid
Thank you for the answer :)
Is it really this simple? No other parts, except those in the power supply?
How can I figure out what trafo to use when it's used on a 4 ohm subwoofer? What secondary voltages, and what VA rating is needed?
I plan on buying ToroidTM trafo, I see you use them Mad_K, are they any good?
Mad_K
yes it's that simple ;)
buy the 600VA 2*24VAC one (elfa nr 56-139-30). they are very good. you have to use a softstart circuit with a trafo of this size.
a pair of rifa peh200 will also be nice (for example elfa nr 67-661-33)
Alcaid
Isn't 600VA a bit overkill? (and budget killer ;) )
How do I build a softstart circuit?
When you say 200W, do you mean peak or RMS?
Thanks for helping :)
Alcaid
Sorry for all the stupid questions, but here's another one:
Is the power supply on the link under good for my project? (With the two Rifas near the chips).
http://www.euronet.nl/~mgw/diy/amps...pply_schema.gif
Anyone got a schematic for a powersupply to recommend?
Mad_K
skip the 0,1uF caps, use regular high-powered bridge rectifier (~25A) and use the peh200 instead of c1/2. on a second thought -use the 0,1uF caps directly on the chip between v+/v- and gnd. ;)
here's some light reading: http://www.tnt-audio.com/clinica/ssps1_e.html
Alcaid
Thanks for that link! :)
Answered all my questions concerning power supplies.
JojoD818
does that mean that the pin 8 of the 2 541s in a parallel mode are tied together?
Thanks,
JojoD
Mad_K
quote:
Thanks,
JojoD
nix
:whazzat:
JojoD818
Mad_K,
I feel so stupid, but can you please be more specific? A schematic will be appreciated.
JojoD
Alcaid
He means a link from after 1st Rout to 1st chip's pin 8 and a link from after 2nd Rout to 2nd chip's pin 8.
In this case after UPPER Rout to U1 and after LOWER Rout to U2.
JojoD818
In that case, I am right then. Because the 2 after Rout are tied together and so will the 2 pin 8s of the opa541.
JojoD
JojoD818
Is this correct?
JojoD
JojoD818
Sorry, too quick on the trigger...:smash:
JojoD
Alcaid
I see from the datasheets that the OPA541 delievers 5A continous and can handle +-40V on the supply. The OPA549 can deliever 8A, but it can only handle +-30V on the supply. From http://focus.ti.com/lit/an/sboa082/sboa082.pdf you can also see that OPA549 has lower THD+N.
How can i calculate how many watt they will deliever at 2ohm, 4ohm or 8ohm? V^2/R=W, but how do I find out how many volt it can deliever. It can't deliever as much as the supply, or am I wrong?
Is current calculated V/R=A ?
I want to find RMS values. Is it then (V/root2)/R=W ?
Alcaid
How do you calculate the efficiency of the heatsink needed? Then you would have to calculate the heat dissipated by the IC, how to do that?
Lots of questions in this neewb head. ;)
Mad_K
from opa541 datasheet "Voltage swing=Vs-5,5 @Iout=5A"
The wattage @4/2 are normally limited by current P=((I*root2)^2)*R. R=8/4/2..
Ipeak=V/R. Irms=Ipeak*root2. for Prms use Vrms and Irms.
To know your psu voltage under load this little tool is helpful: http://www.duncanamps.com/psud2/psud2_setup.exe
Mad_K
use this graph (close enough -lm3875 datasheet)
Alcaid
I've calculated a bit, and I just wondered if you Mad_K think that the Austerlitz KS160 heatsink at elfa (75-626-55) would be sufficient for both of the chips, in this parallell setup driving a 4ohm sub?
Mad_K
yepp! (got 1,4m of it right here...) ;)
edit: I would have recommended that profile, if you hadn't figured it out :)
Mad_K
sorry-didn't see this on. 600va is overkill (but not that big difference in price). I would recommend a 300va one instead (I was thinking stereo). Then you also don't need a soft-start.
for paralell opa541: ((10A*0,707)^2)*4=200Wrms
you're welcome :angel:
JojoD818
Mad K,
Did you see the schematic? Any comments will be appreciated. I am really planning on building a bridge/parallel OPA541.
JojoD
Alcaid
Thanks alot Mad_K!
I really appreciate you helpin' me. :)
Mad_K
Mad K,
JojoD
THAT IS CORRECT ;)
Mad_K
-This was wrong It's 1/root2 where it says root2... (0,707 for practical purposes)
:smash:
JojoD818
Mad_K
Thank you for giving me some of your time in answering my question.
Best Regards,
JojoD
Mad_K
:angel:
Page generated in 0.059633016586304 seconds with 17 queries,
spending 0.00968862 doing MySQL queries and 0.04994440 doing PHP things.
Please support our sponsor.
