diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Someone tryed this? - Click HERE for Original Thread
MaXiZ
Some one tryed this?
I've build it.. PSU is a SMPS at +20@8,5A enough i think..
BUt when i connect the power amp the car stereo turn off and nevere turn on again once i disconnect the power amp...
I've thought that maybe the smps but without the power amp it's all ok.. And this happen when i connet the positive and gnd to power amp.. If i connect only the negative and gnd the stereo remain on but without any sound...
What's maybe wrong?
GregGC
What's maybe wrong?
On the amp SCH it sais +/-V. Are you using single voltage supply (0/+20V). If that's the case you really need a output cap. I don't think I understand well your setup.
Greg
MaXiZ
Exactly
Where should i put this?
I'm not an engeneer! Sorry! ;)
li_gangyi
he's asking if you use dual or single supplies...and if you have an output cap (or is considering one) and can you describe the whole setup u plan to use for us??
MaXiZ
:xeye: sorry!
I use ONE car battery that is directly connected to a car stereo, the SMPS is connected to it and give +/-20@8.5A with 4.400uF per rail.
At the moment for a test i would use this setup..
Car stereo=>Power Amp (tda1514)=>Speaker
GregGC
:xeye: sorry!
Just finished drawing that. and then I red your answer. So forget about my crappy art.
It is a gnd problem I think. Is the GND (-) of the battery connected to the gnd of the SMPS power supplay, or they have no internal connection?
The IC pack is connected internaly to -V. Where did you mount the IC. Is it mounted on heatsink touching the gnd. I suspect something to do with that (since I cant see the actual setup).
MaXiZ
This mean that i mustn't take ur schematic?
naturally yes! Why?
What does this mean?
I've looke and don't seems to me...
Do u mean how the component are mounted?
MaXiZ
and i've noticed another thing...
i've made a test to see if there's a gnd problem as u say..
If IC is connected seems like + & - are directly connected, instead without it like there's a 2000K resistor...
Contact me privatly too.. if u can..
icq:47573544
mail:maxiz@inwind.it
Lars Clausen
If you are going to use a chip amp like TDA1514 you might as well buy it here: http://www.elmatrd.ro/amplificatoare.html
the price is the lowest ever seen.
1000000 Romanian Lei is equal to 29 US$
JojoD818
Maxiz,
Are you sure you checked your connections? If you made a pcb, please try to check your paths. Remember, if an amp is designed to be fed with split supplies, NEVER connect only one rail at a time.
Is a non-smps supply available, a lower voltage maybe? this can help in trouble shooting alot.
JojoD
li_gangyi
try it with a standard trafo and some smoothing caps...helps you reduce the problem to either SMPSU or Amp section...
Page generated in 0.08410906791687 seconds with 17 queries,
spending 0.00793791 doing MySQL queries and 0.07617116 doing PHP things.
Please support our sponsor.
