diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Source to find Amplifier cabinets - Click HERE for Original Thread
ManUtd
Were to find good cheap amplifier cabinets?
Do not want to spend a lot of time making an amateur looking cabinet.Simply do not have the interest in this,but in building
the amp itself.
ManUtd.
joensd
what would you like to spend?
Good looking and nicely machined cabinets are generally not cheap.
You can get a nice 19"-2HE cabinet with integrated heatsinks for about 140€. Have a look here.
This just an example.
It´s definitely no the cheapest cause of the integrated heatsinks.
Cheers
Jens
PS.: Do a search here in the forums. There have been many more suggestions about that topic.
UrSv
http://www.thlaudio.com/casebpwrE.htm
cowanrg
http://www.par-metal.com/
check them out. they can custom make to your size.
GUILHERME
www.audiokit.it
king30
http://www.welbornelabs.com/woodchassis.htm
ManUtd
Great Answers from all of You!! Thanks,
Anyone with experience with some of these?
Pictures of some Examples?
Reg,
ManUtd.
joensd
Mine is here in post6.
I can do more photographs if you´re interested.
Monacor sells exactly the same 19"-case and I think they´re all produced by fischer-elektronik in germany.
Cheers
Jens
bigparsnip
I found something a little different recently (although I don't think you can buy one qite yet, and I wouldn't say that it was cheep) and that should be enough to cool even the bigest alphes. It is in fact supposed to be a totaly passive computer case (dissipating heat from CPU, GPU, PSU and optionaly the northbridge) so it has quite big heatsinks on it. The only small problem I can see with using a couple of these for some moster mono-blocks is that the are likely to cost around 700 euros, each. Ouch
http://www.nordichardware.com/revie.../ZalmanTNN500A/
purplepeople
I've always like enclosures with integrated heat sinks, but they are usually not cheap.
http://www.lawtronics.co.uk/heatsink.html
:)ensen.
GUILHERME
This one probably got what you're looking for:
http://www.diyparadiso.com/price/housing.htm
joensd
By conicindence I recently checked prices with diyparadiso.
Model C cabinet:
no cooling plate 69€
with one plate 89€
two plates 119€
Model E :
0 89€
1 119€
2 139€
Not really cheap IMO but of course it also depends on quality in general and not only the cooling effectivity.
name773
inexpensive
here
GUILHERME
:confused: Not much different from your first suggestion.
joensd
Every finished cabinet will either be not good in quality or expensive. The salesman might be stupid of course but that´s another thing.
My first suggestion is actually quite an OK compromise as it is a rocksteady and heavy thing with two big heatsinks and nice holes in top and bottom cover.
To be honest : I wouldn´t buy it again cause for 100€ you get two (much better) heatsinks and can assemble the rest yourself.
So for around 140€ you get more of course but that depends on if you wanna take the challenge.
I think it´s worth it (not only moneywise)
Cheers
Jens
GUILHERME
Jens,
I never bought anything from diyparadiso so can't comment on the quality.
I did get one of the galaxy models from the other site (audiokit) and found it to be very nice at a fair price, but it was a different kind of project with no need for heatsink.
Guilherme.
Page generated in 0.038686990737915 seconds with 17 queries,
spending 0.00875711 doing MySQL queries and 0.02992988 doing PHP things.
