diyAudio.com diyAudio Forums Archive > Top > Source > Digital
TDA1543 DAC problems -- advice? - Click HERE for Original Thread
Nathan Lewis
I have a 4x parallel TDA1543 DIY DAC rather similar to the Tnt-Audio Convertus design (no output stage).
I've had a real problem recently with a harsh and aggressive high end, especially sibilants. Or rather, I think the problem has been there a while, but it's really starting to bother me a lot.
I've tried a number of tweaks -- replacing the 7805 rectifiers with TL431 shunts, going to passive PS on the TDA1543, battery supply, various coupling caps (Auricaps, BG NPs), various IV resistors (Holco, cheap carbon film). I could try some more IV resistors....
I've noticed this with a number of different amps and IC cables, so I think it's the DAC.
Suggestions?
Nate
Cobra2
Try a different resistor-value(trim) for V ref (output from TDA 1543).
ArneK
sparkle
Hi!
Only time I have experienced problems like You said was when my power supply was not good enough- are You sure that Your tl431 is in good working point - minimally 10mA through it. Do You have really good cap's after the tl431( like Black Gate's or similar- and on input receiver oscon's or similar)- TDA1543 won't be satisfied until it has REALLY good power supply. In my setup I have Riken on I/V and Vref and some silver PiO and MKP's in paralel as coupling cap's- maybe Your resistor and coupling cap's are the reason for that too.
happy diy is that
daniel
Nathan Lewis
Thanks for the ideas. The PS capacitance is rather light, 4x 220uF Cerafines at the TDA1543s, bypassed with 0.1uF at the pins. I tried alligator-clipping in a 2200uF cap, but it didn't seem to have much effect. The TDA1543 supply is passive, a 12V battery with about a 20R resistor to drop voltage, then the capacitors.
The CS8412 (receiver) supply is two TL431s, capacitance is also light, only about 220uF (cerafine) per supply bypassed with 0.1uF after the TL431. I think the TL431s are shuntingtha about 20mA.
Bas Horneman
Now I'm no expert but since you have tried battery supply and all, guess that is not where the problem is.
Dunno if you have read about Doede's DAC. But he states very categorically that you need to trim the DAC with the right RREF and RLOAD AND voltage..to get the lowest distortion and best sound!
http://www.dddac.de/ma_dac23.htm
Hope this helps..
Bas
PS his voltages and resistance where calculated/trimmed for 8 parallel.
jean-paul
Maybe omitting the 20 Ohm resistor and adding a discrete regulated supply for the TDA1543 will improve things. Or try a battery with lower voltage ( 6 V for example ) without any series resistor.
In other words: I think that 20 Ohm series resistance is not beneficial for correct operation the DAC chip. It also ruins the mOhm internal resistance of the battery so the advantages of using a battery are greatly reduced.
The advice to trim the DAC with the right Rref and Riv and voltage is a good advice too.
Nathan Lewis
I was pretty happy with the change going from the LM7808 to the passive supply, but I might try switching back just for curiosity.
sparkle
Hi!
Try to put TDA chip on a 5V and 1.5k for I/V and 1k for Vref. It is ( my opinion) best to do it with ELSO regulator - you can use LM329 in that regulator or TL431 (if you need higher ps for your TDA). I think that if You have tried battery on Your dac- ps is not Your problem (the minute I put battery in my dac there was no harshness in sound but I didn't like the sound overall so I have changed to regulators)- maybe as Bas said to try to change TDA working point. Also try 6.72V on TDA and 2k2 as I/V and 1k32 as Vref. Maybe 8V and 3k as I/V and 1k5 as Vref. If this doesn't work- see to find better resistors and cap's after the TDA- and if that doesn't work- well You are in trouble.
Maybe it is something wrong with input receiver than.....
TDA chip is great chip - only it is very sensitive to everything :D
daniel
sparkle
sorry, one more!:D
TDA will work with only TL431 as a regulator without any harshness or anything- correct combination of the components in power supply will also affect the sound tremendously
daniel
Nathan Lewis
With 4x TDA1543, there's quite a bit of current, about 300mA. Maybe you could use multiple tl431s?
Nathan Lewis
Also, there may be some jitter concerns. I am using a Phillips CDM12 unit in a wooden (unshielded) box. It is very noisy in RFI. Due to layout the digital cable actually crosses the AC power line and comes close to the power tranny.
Bas Horneman
Ah yes...I suspect that could be the real reason for your "problems"...
Does the CDM12 have I2S?
Bas
Nathan Lewis
Yes it does, combining DAC and transport is a future project, and also isolating the power supply (probably more batteries).
On that theme, does anyone have any criticisms about putting transport, DAC and perhaps amplifier in one chassis? I was wondering particularly about vibration from the transport motors etc.
Andypairo
In a discussion with Elso Kwak he mentioned that he had bad results putting a TDA1543 based dac inside the chassis of the CD player, probably due to RFI.
Try shielding it or putting it outside.
Cheers
Andrea
Page generated in 0.036672115325928 seconds with 17 queries,
spending 0.00854850 doing MySQL queries and 0.02812362 doing PHP things.
Please support our sponsor.
