diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
pre amp - Click HERE for Original Thread
uvodee
what do you guys use as a Pre amp for the gainclone as we know it here on DIYaudio or do you use another directsource such as cd player or dvd player with volume controle ?
Jean-Pierre
theChris
depends on if i'm using active filtering or not. if i use active filtering then sure, not much reason not to use it. if it's just an amplifer without need of a balenced input buffer or any processing, i'd just use a non-inverting amplifer with suitable pot.
Ropie
My IGC just has a built in stepped attenuator and selector switch which acts as a passive preamp section. My CD player has a volume control which I use to take the output to very low levels if necessary.
Page generated in 0.016933917999268 seconds with 16 queries,
spending 0.00794578 doing MySQL queries and 0.00898814 doing PHP things.
Please support our sponsor.
