diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
TVC - alternative approach - Click HERE for Original Thread
moamps
First, a few pics:
1.
moamps
2.
moamps
3.
moamps
4.
tiroth
Very nice looking! It looks as though it was a ton of work. How is the sound?
analog_sa
What a nightmare! Can't possibly sound half as good as a simple ELMA/Seiden switch. But it glows and may even have remote...
Peter Daniel
quote:
Although appealing to some, I could never get used to two buttons for changing volume. There is only one way to implement that control and it's the knob.
The metal work and layout is done very nicely though. And I kind of understand the design choices here. Using knobs would change the visual character of the unit and remote is probably easier to implement this way than with knobs. I've seen similar unit on the Bent Audio board selling for $10K, although it's using knobs;)
http://www.audiocircle.com/circles/...28076714a35d4cc
moamps
quote:
Thanks. I hope to compare the sound of this TVC with some other 'classic' preamps (S&B TX102-based and Sowter) in the next couple of days so I can evaluate its sound more adequately. Technical specifications are quite satisfactory.
Yeah, yeah... I didn't expect to hear a word of praise from you. Nor would I want to. And I bet the only proper way to do it is missionary, right ?:devilr:
Thanks. A rotary encoder was implemented in the beta version ;)
Peter Daniel
quote:
So which ones are you using here?
With regards to my S&Bs, initially I was under the impression that TXs dull the highs or take a bit of sparkle at the top end, but after constant using for several weeks, I either got used to it or they simply burned in. They sound very satisfactory now and frankly I don't see a need for an active preamp. They also work well with GC, which are my main amps now.
moamps
I'm using a somewhat unusual combination of 2 transformers per channel (Sowter 9150 + 9155; 4X10dB + 5X2dB). So far so good.
tg3
What are the DB9 plugs for? Programming the chips? Serial interface for remote control?
BTW, nicely done. :up:
moamps
one DB9 I will use for remote control from central remote receiver. (simple TTL logic for volume up/dn, input up/dn, on/off and mute) Second connector is DB15 for level-volume control of additional HT preamps/amps control (simplified version with CMOS-like chips - not done yet). All control logic uses basic CMOS IC's(up/dn counters, converters, logic), diodes and signal transistors.
Page generated in 0.082535982131958 seconds with 17 queries,
spending 0.03140330 doing MySQL queries and 0.05113268 doing PHP things.
