| How can I connect a frequency generator (BNC) to an amp (RCA) ? - Click HERE for Original Thread |
| Bricolo |
I want to test my gainclone, but there's a small problem:
the gainclone has RCA inputs, and the frequency generator has a BNC output, and uses coaxial cable.
For sure, I'll have to build (or buy) a BNC->RCA adapter. But what should I put in it?
Only 2 plugs, nothing more? Or terminate the coax line with a 50R resistor from live to ground?
Alex |
| jwb |
| It doesn't matter at audio frequencies. Just use the converter. |
| Pjotr |
Hi Bricolo,
From many hi-fi shops there are also 75 coax cables available with a RCA cinch at one side and a BNC at the other side. These are intended to connect (home) video equipment together. Such a cable serves me pretty well for the same purpose as you have.
Cheers ;) |
