diyAudio.com diyAudio Forums Archive > Top > Source > Digital
PLL for use with SPDIF (biphase mark encoding) - Click HERE for Original Thread
Akh_Ind
Which PLL (from any company) should I use with SPDIF data ?
Terry Demol
quote:
Guido Tent offers a VHQ PLL reclocking PCB with extremely
low jitter rejection corner frequency and a very low jitter
VCXO. I believe this should be far superior to any chip based
solution available.
He is around here somewhere.... Guido??
Terry
Akh_Ind
I cannot use PCB in my project. I need a PLL itself.
Guido Tent
Hi
I am around.....
I designed a PLL that uses very ow corner frequency and lowjitter VCXO and low noise power supplies
It is intended to upgrade DACs, where clocks have jitter from 200ps to 1 ns. My unit cleans it up to 8ps
I can send you seperate information if you like
best regards
machinow
Hi Guido.
Can this VCXO be made with discrette components?? I mean with diodes /varicap??/ and a crystal. It should be possible. I suppose you have tried this method. What are the results??
The vcxo modules are very hard to find /here/. Does farnell sell them??
The other metod is using the not-liked-by-everybody ASRC like AD1896....... But this is a different design.
regards -
f.k.l.chan
hi Guido,
do you have a web page? where can i get the infomation about your PLL?
Leo
Guido Tent
quote:
Originally posted by machinow
Hi Guido.
regards -
Hi
Yes you can build a VCXO yourself, but I also sell canned modules, with or without PLL circuit (called XO DAC).
I have built discrete VCXO's but prefer canned modules as these are less sensitive to external disturbance.
regards
machinow
Thank you, Guido
best Regards
Page generated in 0.032309055328369 seconds with 17 queries,
spending 0.00732780 doing MySQL queries and 0.02498126 doing PHP things.
