diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Double Sided PCBoards - Click HERE for Original Thread
cm961
Hey guys,
Been awhile... hehe.
I need to make a double sided board. I'm using the MG Chemicals presensitized (or whatever) double sided board, and I don't quite know how to expose it. I've done a few single sided boards. Do I just expose one side, flip it over and expose the other?
Pete
macboy
It's tricky, but it can be done.
You should mark and drill a few holes, to act as references to align the top to the bottom. Also remember that since you can't really make plated-through holes like the pros do, you have to use solder a short piece of wire through any vias, and of course, solder all through-hole components to both sides of the board (where there is a solder pad on both sides).
You might consider some of the PCB shops, some of which will proto a board for around $20. Do a search in the forum.
cm961
Wo that would be awesome, since the double sided board cost me about that. Also I noticed your in Ottawa like me, maybe you know somewhere local?
Pete
macboy
I don't know of any places in Ottawa that do cheap PCB prototypes.
If you search this forum, you can find several threads dealing with making and buying protoype PCBs, such as this one.
Page generated in 0.020966053009033 seconds with 17 queries,
spending 0.00892091 doing MySQL queries and 0.01204515 doing PHP things.
Please support our sponsor.
