diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Spdif - Click HERE for Original Thread
Akh_Ind
Can anyone tell me how to extract the clock from incoming SPDIF DAta ?
RobM
Use an SPDIF interface chip (like the CS8414) and grab the clock line off of that ;)
Akh_Ind
I beleive this chip recovers the clock from the incoming data using a PLL. I wanted to know whether there is any other method also to recover the clock.
Guido Tent
quote:
You may use the CS8415 as it uses the preamble to feed the PLL circuit. At leat the data dependancy of the jiter decreases.
If you want to do a better job, you may consider a secondary PLL circuit with much lower cut off frequency and a decent VCXO.
In my designs I obtain about 8 ps jitter.
regards
Page generated in 0.1842839717865 seconds with 17 queries,
spending 0.14309573 doing MySQL queries and 0.04118824 doing PHP things.
