| soundNERD |
| Can the LM386 be used as a headphone amplifier? Would I have to set the gain below 20 to do that, and is that even possible? Or would I have to use a resistor on the input or something? I don't need a volume conrol, since the audio out of the CD player is controlled. |
| audioPT |
Yes, it will work.
But don't expect good sounding :whazzat: |
| seangoesbonk |
No, the LM386 can't be set to a gain below 20. This is way too much for a headphone amp. There are definately better options.
Because of the relatively low power and gain involved in a headphone amp, you are probably better off using a standard op-amp. |
| tbla |
| quote: | | This is way too much for a headphone amp. |
not for the k-1000...................................;) |
| seangoesbonk |
| quote: | Originally posted by tbla
not for the k-1000...................................;) | I DEFINATELY wouldn't use a LM386 for the AKG K1000, although after you buy those headphones, you might only be able to afford to use a LM386. ;) |
| Vigier |
I suggest you use a OPA627 or OPA637 with a BUF634 after it. The OPA will give the necessary voltage swing, and the BUF634 gives enought current (250mA).
Instead of the (in comparison to the LM386) rather expensive OPA627/637 you could also use the NE5534, which is cheaper and sure good enough if you planned to use the LM386 at first.
Grtz, Joris |
| Brannigan |
| quote: | Originally posted by Vigier
Grtz, Joris | Something like this maybe? |
| Vigier |
Yessssssssssssss..... :)
Grtz, Joris |
| moamps |
Hi all,
just for info,
older professional cass Tascam 122mkII uses LM386.
Newer professional products from Tascam (MD801, DA30,..) use LA6510 power opamp in headphones amp.
http://62.236.156.23/ideaport/d/la6510.pdf
Regards |
