| Peter Daniel |
I've built those years ago, and recently wanted to use transformers for gainclones so I disassembled the amps. They were used for surround, when it became popular in early 90 's.
Ea. module contains two amps. rated 120W RMS into 8 ohms (+/- 55V supply). I'm asking $60 for everything. Shipping shouldn't be more than $15 in US and probably cheaper in Canada. |
| Peter Daniel |
| So basically you are getting 4 channels rated 120W, except that one module is broken (didn't check it , but some resistors burned due to output shorted). |
| Peter Daniel |
They also contain capacitors and bridges (15,000u per rail on ea. amp). The size is approx 6 x 6 x10".
This was one of my first projects in Canada, so don't blame me for sloppy execution;) |
| Peter Daniel |
| Here's the schematic. This came as a kit purchased from a local Chinese store. The output devices are Hitachi 2SK135 and 2SJ50. |
| Upupa Epops |
| Peter, how you can recomended power rails 55 V, if I see on the picture caps for 50 V ?:scratch1: |
| Peter Daniel |
| quote: | Originally posted by Upupa Epops
I don't recommend 55V rails. If you read carefully, you'll notice that only full power is specified at this voltage.
| quote: | Originally posted by Peter Daniel
Ea. module contains two amps. rated 120W RMS into 8 ohms (+/- 55V supply). |
Since I'm selling modules without transformers, it is up to the buyer to decide what transformer he wants to use. If using 55V rails the caps have to be replaced. I was using 35V AC transformers for couple of years, so caps should be replaced anyway now;)
Any takers at $30 for everything? I would hate to put this on a garbage. |
| li_gangyi |
| HEY I WANT IT~!!! But can you tell me in private (PM or E-mail me) how much is the shipping to Singapore?? Want some for a project...here's my answer...hehe |
