| Matt D |
None of the drivers listed below are standard production units. They are all samples or prototypes. Unfortunately I don't have specs for most of them. I'll describe them best I can. If you need more info, I'll try to answer questions on them. All of the units are new.
3 pcs. HT170PM step4 - This is the Audax PR170M2 high power
mid in a steel basket instead of cast $15/ea or $40 for 3
2 pcs. HT170M04PMS - 6 1/2" woofer w/dark silver painted
coated paper cone, smallish motor foam surround $15/pr.
1 pcs. HP170PGX - 6 1/2" paper cone rubber surround w/10mm
coax tweeter $7/ea.
1 pcs. AM130Z - pre-production version of AM130Z2 $10/ea.
1 pr. HP130F - 5 1/4" copper colored fiberglass cone rubber
surround $15/pr.
1 pc. HM130PT - 5 1/4" coated paper, fabric surround cast basket
large magnet high output mid/midwoofer $15/ea.
2 pr. HP130PG - 5 1/4" coated paper rubber surround large motor
high output mid/midwoofer 1 pr has fabric dust cap, 1pr has
poly dust cap $20/pr.
2 pr. HM210Z - 8" aerogel cone, cast basket, phase plug, similar
HM210Z0, 1 pr. has inverse rubber surround, 1pr. has
positive roll rubber surround $50/pr.
1 pr. HT170X - 6 1/2" TPX cone steel basket $25/pr.
1 pr. AT170X - 6 1/2" TPX cone steel basket shielded $30/pr.
Thanks for looking. E-mail me with questions mwdaigler@adelphia.net
Thanks,
Matt |
