diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Components in my CD player - good or bad? - Click HERE for Original Thread
staffann
I have checked my Vincent CD-S3 CD player in order to see if there are any components that badly needs replacing.
Can anyone say how good or bad the following components are:
OP-amps:
After the DA converter is a OPA2134 - a double op amp
After that a NE5532 double op amp per channel
Then an OPA2604 double op per channel
By the balanced outputs one more OPA2134
Voltage regulators:
One LM317T overf by the clock
An A1837 at the D/A omvandlaren (is this a voltage reg?)
A LM317T at the analog part
The clock is built with an oscillator, a 74HC74 flip-flop and a 74HC125 buffer chip.
I would very much appriciate any help!
Page generated in 0.028073072433472 seconds with 16 queries,
spending 0.01960254 doing MySQL queries and 0.00847054 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
