diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Proper Bypassing for a Virtual ground Load - Click HERE for Original Thread
ppl
The illustrated schematic denotes my version of bypassing a virtual ground connected amplifier load. Analog Devices app not an-202 denotes this method to contain the load within a small loop. I took this one step further and added a 10,000pF Polystyrene capacitor on previously un bypassed sides of each section. The 0.22uF Teflon capacitors are the largest value I can put in the space allotted so hopefully that is a large enough value. Any thoughts on if this is a valid method in this situation of if better alternatives exist. Thanks in advance
Pg3 fig 3A showes the method hear.
http://www.analog.com/UploadedFiles...08865AN-202.pdf
Page generated in 0.053261041641235 seconds with 17 queries,
spending 0.04312611 doing MySQL queries and 0.01013494 doing PHP things.
Copyright ©1999-2009 diyAudio.com
