diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Need help identiifying a chip - Click HERE for Original Thread
soundNERD
An old car stereo reciever broke, so I pulled out the boards and took off the useful components. Still on it are two chips. I am sure one of them is the amp. here they are:
HA13139
Pioneer PA2019A
What are these chips?
Netlist
Hi soundNERD
As far as I can dig, it’s pretty hard to find a datasheet or any other info on these chips.
You’ll have to contact Pioneer with some smilies.
HA13102 to HA13135 are all power amps.
So, HA13139 is probably the power amplifier, the other one, no idea.
Pictures of the board?
Greetings
/Hugo
soundNERD
Heres a picture. They were both attached to a metal clip. Didn't look much like a heatsink, but I am not sure. There were no fins or anthing, it just was flat and wrapped around the chips. The amp is probably 4 channel, right? since it is from a car?
Thanks, Mike
soundNERD
I noticed that after I posted the picture isn't too good. If you need to see it better, I can take one with my digital camera instead of my webcam. Also, the chip is the one on the right in the back, and it has 16 pins.
-Mike
Netlist
quote:
-Mike
Yes please :)
/Hugo
soundNERD
Here it is.
Also, as the thing broke, I tore off the caps and resistors and other useful things, which is why the board is so empty.
soundNERD
Heres just the amp chips:
soundNERD
Sorry thats a little blurry too, too close for my digital cam to focus on. I think it was trying to focus on the magazine in the background.
Netlist
soundNERD,
since both chips are build to mount on heatsinks, they both could be power amps.
As per my earlier post, I'm pretty sure the HA13139 is one.
The main problem however for you is what to do with these chips if you have no pinout and other data?
Again, unless someone else knows them or has datasheets, Pioneer will be your only option.
/Hugo
Page generated in 0.022366046905518 seconds with 17 queries,
spending 0.00607800 doing MySQL queries and 0.01628804 doing PHP things.
Copyright ©1999-2009 diyAudio.com
