diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Good inexpensive heatsink source? - Click HERE for Original Thread
Doovieman
Anyone know where to find nice big but inexpensive heatsinks? Preferably, not used before... I've seen some other postings that show huge sinks...I'm looking for something on the order of 3 inches long (maybe even a bit less) and 6 inches wide. Thanks.
Doovieman
seangoesbonk
I've used these:
http://www.bgmicro.com/prodinfo.asp...at+sink&stype=3
I ordered 6 of them and they were unused, but about half of them had minor surface scratches on the ends. (You could see the bare aluminum, but no percievable amount of metal had been removed.
You can see them in action here:
http://members.shaw.ca/seangoesbonk/sgb3886.html
Edit: If you are interested in these, I can email you about half a dozen close-up photos of these.
mercator
I bought a couple about that size from BGMicro for 3.99 each - cat. id ACS1395. Planning on using them for a gainclone (or 2). The only problem is the fins run the wrong way for me.
Might be suitable, check out:
this page
Dave
I see seangoesbonk beat me to it.:xeye:
seangoesbonk
quote:
I beat you to it!
I used a pair of these in a LM3886 quad channel gainclone. (38wpc, 28Vdc rails) I use it with a pair of Tangband full-range fronts and a DVC Adire Shiva.
I was worried about the orientation of the fins, but it barely gets warm after a couple hours of use.
Doovieman
hmmm...those are nice but I'm looking for something with the fins running the other direction and preferably silver. Any other suggestions? Thanks,
Doovieman
uvodee
but I like Steve from www.apexjr.com
and the stuff he has, he turns out more and faster than he can put on the websdite, that is why you should call him just in case.....
I have gotten some unbelievable deals from that place....
J-P.
Doovieman
That apexjr is pretty hot. They're sinks aren't quite what I'm looking for but they're definitely a great resource...Thanks!! Any other suggestions for sinks?
sam9
You are in Berkeley, right? Check www.halted.com. If you havbe the time, the best bet is to drive to one of their shops. One is in Santa Clara( Lawrence Expressway and Central), one in Rohnert Park (just off 101 between Santa Rosa and Petaluma) and Sacramento.
No guarantees but there is a good chance you might find something.
bknauss
Another vote for Steve at ApexJr. Nothing but wonderful experiences with him.
Apex Jr
Thanks guys for the good words.....
I have some small quantity's of used heat sinks
not listed on the website:
1st going to Doovieman if interested.
4 ea Aluminum 4 5/8" X 8" X 1 1/4 26 fins flat bottom $7.50ea
2 ea Black anodized aluminum 4" X 13" X 1 3/8 40 fins
also a flat bottom $10.00ea
5 ea Aluminum 7 1/2" X 10" X 1" 28 fins flat bottom $12.50ea
Steve @ Apex Jr
www.apexjr.com
JCoffey
If Doovieman doesnt want the 2 black anodized sinks, I'm interested as I've been needing something along those very lines for the gainclones I'm building.
Steve, if he doesnt express interest, could you please email me?
Thanks,
Jonathan
Apex Jr
Doovieman is interested in the 4 5/8" X 8" heatsinks
leaving the black anodized available. Contact me
as I will hold them for you.
Steve @ Apex Jr
jackinnj
Aavid Thermalloy has a Heat Sink Calculator on their website:
here's the URL:
http://www.aavidthermalloy.com/technical/thermal.shtml
Page generated in 0.032465934753418 seconds with 17 queries,
spending 0.00640392 doing MySQL queries and 0.02606201 doing PHP things.
Copyright ©1999-2009 diyAudio.com
