| johnferrier |
I'm interested in a emitter follower with active current source design to buffer op-amps with differential outputs. I've sketched a design:
If this seems reasonable, I probably will parallel the NPNs (4 per side) to obtain 80mA class A for each output.
Has anyone seen anything like this? I'm mostly interested in a transistor design non-complementary.
I don't mind dealing with heat issues. This amplifier is to drive headphones.
Comments welcome.
JF |
| Christer |
To me it looks basically like two half diamond buffers in
bridge coupling. Have you considered using two full diamond
buffers instead? In theory and in measurements the diamond
buffer has excellent distorsion figures. I am sure different
people have different opinions on which sounds best. I have
no opinion as of yet, but I am currently working on a board
design with opams followed by discrete diamond buffers, so
I expect testing it in the near future. |
| Bricolo |
since he wants class A, why should he bother with the other half of the diamond buffer?
I still don't understant the benefict of push pull class A compares to SE class A |
| Christer |
Because a full diamond buffer is also class A, if properly biased
and, at least in theory, it lacks even-order distorsion when
the output transistors are matched, while a half diamond
buffer has quite a lot of second-order distorsion. I do not
know which of the two has the lowest amount of odd-order
distorsion, but the full diamond buffer performs excellently
in this respect as can be confirmed by calculations or SPICE
simulations, and has also been confirmed by measurements
published by Walt Jung. |
| Bricolo |
| hod did you measure distortion with spice? |
| johnferrier |
| quote: | Originally posted by Christer
buffer has quite a lot of second-order distorsion. |
I'd like to know why half a diamond would have much higher second order distortion, then a full diamond. I wonder if it is because it slews on faster than off. Of course, I expect some distortion cancellation (especially, with second order) because I'm using a differential bridged circuit.
I don't see much "half diamond" circuitry. The old BUF-03 used more of a non-complementery emitter follower out. Of course, newer buffers use complementery diamond topology.
Well, igonoring the fact that non-comp emitter followers are rare (only because of inefficiency?), I'd like to find a reference that indicates that the full diamond performs better than the half diamond. Again, efficiency aside.
Thanks for the replies.
JF |
| Christer |
| quote: | Originally posted by Bricolo
I let my CPU sweat and give me some value for the money it
cost me. :)
Basically, I run a transient analysis of desired source amplitude
and frequency and then do an FFT. I always make sure to do
an FFT also on the source signal as a reference, to see that
the simulation parameters chosen give none, or sufficiently
low distorsion on the source signal. Empirically, but testing
various trade-offs I have settled on the following parameters
in most cases. I run 21 cycles, starting to collect data after the
first one, ie. 20 cycles are analysed in the subsequent FFT.
I also set the minimum step-length to 10E-5 times the cycle
length, ie. for a 10 kHz source signal, the step length is 1ns.
Then I FFT those signal, including the source, that interest me,
choosing a large number of data points, usually 1Meg. I have
found this to produce a noise floor of around -120dB or better,
which is usually sufficient. you can improve of that, but it takes
quite some time already with these parameter values, so it
is hardly worth it.
Just don't forget, no simulation is better than the models used
and the simulator may produce strange effects in certain odd
cases.
| quote: | Originally posted by johnferrier
JF |
The exponential transfer characteristic of a BJT causes a lot
of distorsion, both odd and even. In the SE (non-balanced)
case, you get all of this. With complementary output BJTs you
get a distorsion cancellation. I have done simulations on the
diamond buffer, and with perfectly matched BJTs the even
order distorsion seems to cancel out completely, but there is
still odd order distorsion. Changing either IS or BF of output
device, which corresponds to mismatch in Vbe or hfe respectively
will introduce also even order distorsion.
In the simulation I run, where I used a
rather high input signal and heavy load to see distorsion effects
clearly, I got -81dB 3rd order and no 2nd order distorsion.
mismatching BF by a factor 4 between the output devices gave
the same 3rd order distorsion, but introduced -86 dB 2nd order.
Mismatching IS by a factor 2 also gave the same 3rd order but
introduced -114dB 2nd order. BTW, these tests were done at
10kHz and using the procedure explained above.
Unfortunately, I do not remember the exact load conditions etc.
Since I was only interested in the effects of mismatching when
I did that analysis, I only jotted down the distorsion figures
on a paper.
After your recent question, I decided to try the SE (non-balanced)
version. I am not sure if the bias current and load resistance
are the same as in the previous simulation, but I think they
are about the same. The result I got was -60dB 2nd order
distorsion and still -80dB 3rd order distorsion. It thus seems
that the diamond buffer cancels even order distorsion only.
I also tried your balanced setup, but for some reason I cannot
figure out right now it didn't work. I think the reason is
that I took your variant with only series resistors on the inputs,
which does not bias the amp properly if the input signal is
differential. I would expect this setup to cancel distorsion
also, perhaps better in practice than a single, non-balanced
diamond buffer set-up, since you have two NPNs cancelling
each other, not complementary devices. That's just a guess
though.
As for referring to it as a half diamond buffer. Well, I thought
is sounded appropriate, but others may disagree. It is no
important issue what to call it, and that easily just leads to
a philosophical discussion. |
| djk |
Can you re-wire your headphones for a four-wire plug instead of the common three-wire plug?
He will still get second harmonic reduction because of the bridge connection. |
| Christer |
| quote: | Originally posted by djk
Actually I said that I believed this to be the case and the
reduction possibly even better than for a (non-balanced)
diamond buffer.
OTOH, what I originally meant in my first post was bridging
two diamond buffers, which I suspect would be even better
than bridging to SE buffers. |
| johnferrier |
Christer,
Thanks for taking the extra time to do this. And I like the idea of a bridged pair of diamond buffers--a double diamond--as being the perferred topology. I need to spend more time with your post to make sure I understand what you wrote.
JF |
| Christer |
As I said, I suspect the bridged diamond buffer to have the
be the best performing of the alternatives discussed. Besides,
It will dissipate less power in the transistors, making cooling
easier, PSU req. slightly less demanding, at a slightly higher
component count and complexity. However, If you do not
absolutely need a bridged setup, I would suspect a single
diamond buffer performs well enough. I hope to experiment
with one soon myself.
BTW, unless you have already read it, I strongly recommend
reading Walt Jungs article on the discrete diamond buffer:
"Walts Tools and Tips, Op-Amp Audio, High performance
buffers (part II): Electronic design, Oct. 1, 1998".
I don't know if it is online still, though.
As for my effort, it was quite interesting and educational for
myself too. ´Trying to answer other peoples questions often
force you to think deeper on the issue which sheds new light
on it. Being a university teacher, I stronlgy believe in the
idea that you don't really know a course until you have taught
for a couple of years. |
| johnferrier |
Okay, I now favor the diamond buffer (rather than the half diamond), but still plan to use a bridged (double-diamond) outputs. I'm willing to pay for a little more performance. Since, the symmetry-bridged topology does nothing for odd-order distortion, I will also see if I can find techniques to lower that too (does this mean MOSFETs?). I will search around.
Also, I did find Walt's article for op amp buffer, using the Wayback Machine--the internet archive.
And yes, I learn by trying to answer questions too (usually, I learn that I don't know quite as much as I thought).
Thanks and good luck with your circuitry!
JF |
| PRR |
The constant-current "Class A" topology dissipates twice the power of a true push-pull Class A amp. Here you are dissipating 4.8 watts to get 0.95 watts in the load; push-pull Class A with the same drop-losses would be under 2.5 watts heat. This may not be too important at headphone levels.
With the constant current topology, device current swings from zero to 160mA; with push-pull it swings zero to 80mA. The lower swing tends to less distortion. The difference may be too small to worry about.
As noted, you will need a 4-wire headphone connection, not the usual 3-conductor plug, but I assume you saw this.
What are all those resistors??? Why have you taken a Diamond and cut one side off? Those resistors are to make both sides of the diamond play nice together. The 10 and 1Ω Emitter resistors set the currents, but here you have set current with current sources so you do not need bias resistors. The 10Ω emitter resistor adds impedance to the drive of the output transistor which we really don't want. The 1Ω emitter and and 10Ω load resistors just waste power, you don't need either one. The 1K gives problems when the two sides of the diamond do not cancel bias current, and is worse when there isn't any cancellation at all.
Why even have two stages? For 80 or 160mA peak output current, any good little transistor needs only a couple mA base drive, well within the ability of any op-amp you are likely to use, even if you yank the opamp into class A. The B-E voltage variation does not cancel between first and second stage, so distortion of a one-stage design is not necessarily higher. Using one stage does mean, if you do not take DC feedback around the buffer, that there will be a 0.7V offset, but it will be the same at both sides of the headphone so there is no DC in the cans.
Then you have:
I've added a small resistor in the collector, to put some limit on fault current without much/any effect on sonic performance.
That will work quite well. Full push-pull both sides can be cooler and lower distortion, but now you need those emitter resistors back.
Interestingly, the Diamond can give lower THD if carefully trimmed in class AB than when working Class A. However the distortion spectrum shifts from mostly-low-order (Class A) to high-order (Class AB). You can make the 3rd vanish, but the 5th is unchanged, and the 7th rises a bit. The ear is the only judge of this. |
| Richard C |
In favour of SE operation:
Since music contains odd and even harmonics I think care needs to be taken in using configurations that favour one over the other. Push-pull looks attractive due to second harmonic cancellation but may not be the best in terms of sound quality.
The single ended design will produce higher total distortion but probably with a more even distribution of odd and even harmonics. |
| Christer |
| quote: | Originally posted by Richard C
With the disclaimers I stated that it is only simulation and that
there might have been slightly different load and bias
conditions, the result I posted indicated that the 3rd order
distorsion was the same for SE and diamond, while the latter
lacked 2nd order. It's difficult to predict from theory what the
ear will like, and many seem to think 2nd order distorsion
make wonders, but will 0.01% 3rd order distorsion really be
less disturbing if you "mask" it by a 10 times higher level
of 2nd order distorsion? It would be another story, perhaps,
if we could decrease the 3rd order distorsion at the cost of
increasing the 2nd and get a higher total distorsion figure,
but that seems not to be the case here.
The analysis is simplified and non-conclusive of course. PRRs
remark on biasing the diamond buffer to class AB was interesting. |
| johnferrier |
PRR,
First, thanks for your long post (discussing transistors) over on the Jung Regulator thread. I need more time to absorb what you wrote.
As far as heat, I've got relatively large heatsinks. And I plan to use 4 wires to the headphones--no problem.
The resistors, he...he...he... I wondered if anyone would say anything. I used those values (1 and 10 ohms) only because I read John Curl write that 15-18mV was an optimum value across Re (I used 20mV). Now that was for the emitter resistors.
I have the input (1k) and output resistor there so that I could parallel the circuit (probably only the output transistors though).
As far as two stage, well the diamond circuit uses two stages. However, the first stage is used to bias the output. I've got current sources to do that.
Richard C,
Yes, I'll try to balance the odd and even THD. You're suggesting SE achieves that.
Thanks.
JF |
| PRR |
Not the same.
The harmonics in amplifier distortion are exactly 2X, 3X, etc the fundamental and always phase-locked.
The harmonics in music are (generally) not exactly 2X or 3X the frequency of the fundamental, and not phase-locked. (Synthesizers are an exception; electric guitars are a complex mix of string inharmonicity and amplifier harmonics.)
The ear may be fooled, mistaking amplifier low-order distortion for "richer music". However only tin-eared rockers (like me) should be fooled by high-order "harmonics", which in normal musical instruments are NOT multiples of the fundamental but in an amplifier are perfect harmonics.
And we use single-tone harmonic distortion just because it is an easy test/simulation. If you go to two-tone: two clarinets on one stage will not intermodulate each other (to detectable degree). Two clarinets through an amplifier always will IM. The IM on complex milti-tone signals (real music) can be astonishing even when THD is low.
I think that higher-order THD means more IM for the same percent THD; however that's not what we measure on current amplifiers. Maybe just because the THD is so low that we are not really measuring harmonic production. On old low/no-feedback amps, the 1:4 60:7KHZ IM number was pretty sure to be four times the THD number; but as we supress THD this old guide becomes invalid.
Neither one reliably "favors" musical harmonics, since the real musical harmonics are not perfect harmonics. If they were, then it might be possible for a high-2nd-THD amp to cancel the natural 2nd harmonic of an instrument, or boost it. In real life, the natural harmonic will go in and out of phase with the amplifier harmonic, "throbbing". The 3% or 10% THD numbers we accept on simple no-feedback amps limit "throbbing" to a small piece of a dB, ignorable.
Opinions and theory aside: we see happy music lovers with topologies from SE Triode to hyper-feedback. The ear must have a very complicated weighting rule for artificial harmonics. It clearly ignores 1% or more 2nd, yet complains painfully about a trace of 13th, yet another amp with slightly different trace distortion is well-loved.
Sometimes the best way to pick a configuration is to look at cost. In a loudspeaker amp, JF's plan would be mighty expensive (at headphone levels and with personal labor, this is no big deal). Instead of paying for oversized transformer and heatsink, you fancy-up a basic Class B stage to hold it in AB, reduce Gm nonlinearity, and probably (not always) add gain so you can use feedback.
Going back to JF's situation: as long as he's using op-amps anyway, an "absurd" yet perfectly workable plan is to get a couple dozen op-amps (cheaper in full-tubes) and parallel them (with appropriate connection so they don't fight). Most modern opamps JF would use for audio are loafing in 1KΩ. He could strap two quad-packs and drive 150Ω (one side of his bridge). That's 8 or 16 chips for stereo, but a simple design and perhaps a "simpler" distortion by omitting a booster stage. (IM multiplies with number of hard-working stages.) |
| PRR |
For what?
28-30mV is a theoretical optimum for a Class AB push-pull emitter-follower amplifier with a very low impedance drive.
In Class A, that works (though bias stability is tough and higher is not bad).
Where the driver is not very-low-impedance, the optimum shifts. My impression for the Diamond Buffer with emitter resistors is that the optimum may be half of the above case. That may be Curl's 15mV-18mV, though without knowing where he wrote this I am just blind-guessing.
And 15mV or 30mV is all wrong for many other topologies.
Bias stability in the Diamond is not good, unless you match parts. And you can NOT match a PNP to an NPN. The resistivity is higher in PNP. You can match Vbe, or you can match Hib, but unless you carve them both on one waver and adjust the area of the PNP you won't get a good 4-way match. That turns out to be the practical limit on Diamond Buffer performance. It can be very-very good, but with real parts it can't match theory. And with real parts, it tends to have significant offset (output sits about 70mV more positive than input).
As to whether single-ended, push-pull, constant current, or light-bulb sources sound "best": IMHO, a well-designed version of any of these should be "faultless". Often the "sound" is not in the topology but in a capacitor (or some trickery needed to "avoid capacitors"). Sometimes we "want fault" to "enhance sound". I've been called a pragmatist and you should have different opinions and preferences, but I think any of the above will work fine if you get all the small details right. |
| Christer |
| quote: | Originally posted by PRR
For what?
PRR,
I suppose he is referring to this post and some of the follow-up
discussion. Myself I have no opinion, not having read the
HP article.
http://www.diyaudio.com/forums/show...4296#post244296
Further, thanks for your very interesting discussion of
instument vs. amplifier harmonics, as well as for other
recent interesting posts here and in the regulator thread. |
| johnferrier |
Okay, here are sketches of my alternatives.
BRIDGED ACTIVE FOLLOWERS
JUNG DOUBLE DIAMOND BUFFER
I'm using a cross coupled OPA637s. (Concept found on last page of the AD8610 datasheet: http://www.analog.com/UploadedFiles...AD8610_20_c.pdf)
Initially, I had thought a simple active follower was a bit basic. But, now sketching it out with the cross coupling, it seems like it may have just the right amount of sophistication.
The double diamond is still appealling and I don't mind the extra work involved in constructing it. Which circuit is best?
The 2SC3953 (2SA1538 w/datasheets http://www.datasheetcatalog.com/dat...2/2SC3953.shtml) seems like a super part to use.
Let me last add, my initial plan was to use BUF634s (which I have). However, I really like to use discrete circuitry at the output.
Anyone have further thoughts???
JF |
| Christer |
John,
why do you insist on bridgecoupling? Previously I though you
had balanced input, but I see now that is not the case.
It will certainly give a cancellation effect, especially for the
active followers, but is it worth it in the case of diamond
buffers? I am not saying you shouldn't do, it may still give
some improvement, but the diamond buffer already has a
lot of the cancellation, although only from complementary
BJT types. You would save a $$$-prices opamp per channel,
considering your choice of type. Just trying to make you think
twice. I don't mind overkill, and might try it myself some
day, perhaps, but think about it.
Edit: It is probably just that you have omitted stuff that is
not relevant to the topology to simplify the schematics, but don't
forget the protection diodes in the diamond buffers, especially
those from input to output. Jung seem to consider them
important when the buffer is preceeded by an op amp and
within the closed loop. I also think the capacitors closing the
feedback loop already from the op amp output at HF should
not be omitted. |
| johnferrier |
I'd like to try something that is a bit different. If nothing else, so that I have something interesting to discuss. I've got op amps. Yes, this is overkill. I hope not at the expense of good sound.
And I have plans to protect the headphones from DC (~+/-50 mVdc across the outputs trip). Also, plan to bias the op amps into class A with 2mA current sources (not drawn).
I wished I could use balanced inputs. However, I also need to include a volume control. So, I'd like to avoid an attenuator with four poles.
Thanks for your cautionary notes Christer!
JF |
| Christer |
By all means, do it. I just wanted you to think about it so you
know why you are doing it. I hardly think it will deteriorate
the sound.
It should be an improvement, I guess, at least in theory and
measurements.
I don't want to confuse you further but since you are prepared
to take the complexity of bridging, have you considered using
CFB op amps and using Nelsons X scheme?
I haven't had time to analyse that special cross-feedback
you use, so maybe it is similar to the X, though.
I am currently working on something similar as you, so it is
interesting for me to.
However, I will use single diamond buffers and no
bridging. On the other hand I will have sockets for two sets
of op amps and a switch for A/B comparison between them, as
well as some other swithces and jumpers for various options.
That is meant more as a testbed than a finished project. |
| peranders |
John, before you are floating away into the swamp sort of speaking, how much power (voltage) do you need for your headphones? +-36 V will fry both your ears and headphones!
Second, can your headphones be driven from a bridge amp? Sennheiser maybe but do you have an another brand? |
| Christer |
| quote: | Originally posted by peranders
And what solution would you propose? Running the buffers
at a lower voltage than the op amp is a no no, and it seems
most agree that op amps perform better at high supply
voltages. The bridging doubles the possible voltage swing,
of course, but even the non-bridged variant vould give
close to +/-18V, which is probably also too much for the
headphones. Thus, in either case one has to either be
careful with the volume control or include some overvoltage
protection circuitry, as far as I can see.
| quote: |
Has already been asked and answered.
Actually my old headphones has an ordinary 1/4" plug, but
the cable is a twin coaxial which splits close to the headphones,
one coaxial going to each side of the phones. These could
easily be converted to work in bridge mode if I wanted to, and
I guess there are many haedphones that are done that way. |
| johnferrier |
I'm aware that 20Vrms would be extremely loud with all but very ineffecient headphones. The datasheets I read (in the "swamp") indicate that circuits operate better at higher voltages. If nothing else, at normal listening levels, clipping will not be a problem. (Perhaps, though not likely, I will use the ineffecient AKG K1000.)
Likely using Sennheisers that easily modify to work with differential circuitry. (Currently, have Sennheiser Ministar MS100. Broken head strap for years, with intermitent contacts--may use conductive epoxy to fix. The the MS100s are the one thing I know of that I *can not* find something about on the internet. Kind of an enigma.) Will use the Ministars to test my amplifier, after testing with 300 ohm 1/4W resistors.
Unsure of the Nelson X, though it seems like these circuits are close. Prefer output transistors rather than MOSFETs. Also, not aware of people raving about the X. Also, prefer VFB to CFB. If my circuits are not Nelson X, then I'm trying something a little different.
Originally, I thought of using switches and relays to easily A/B circuitry, but decided that I wanted to avoid a never ending design. I'd like to avoid trying this and trying that. Also, doubt that my ears are that sensitive.
JF |
| Christer |
John,
The X concept does not rely on MOSFETs or anything. It is a
more general topology, but does assume CFB amps. However,
I had no intention trying to talk you into doing an X amp instead.
I just thought there might be some similarities, so I just wanted
to give you a pointer in that direction, and then leave it to
you whether to follow it or not.
As for switches, it is rather the other way around for me. I
planned a buffer + discrete diamond buffer combo. Then I
thought that an op amp doesn't take that much space
comapred to a discrete buffer, so why not have two sets of
them and and A/B facility? Then I started thinking about other
options too. I admit my design were about to turn into another
everything-but-the-kitcheen-sink design, but I think it is doable.
What worries me most is long non-straight feedback paths
because of the switches.
Well, you have double buffers, I have double op amps. :) |
| johnferrier |
Why not single pole switches to control good DPDT relays that non-energize in the prefered state? SPST switch is cheaper. Relay is more expensive, but you can put it right next to your circuit. Alternatively, you could use header and jumpers. Regardless, I agree that having a quickly way to switch A and B is preferable (rather than powering down and changing parts). As I wrote, my ears are not super sensitive, so I would need all the aid I could get to have a good A/B comparison....
I note that you started another thread. I'll read through it later today to see if I can contribute.
Thanks.
JF |
| Christer |
I have thought about relays too, and maybe that would be
better, but I might still need quite many relays and I happen
to have some switches that are suitable. I will use jumpers for
certain options that I will not use for A/B comparison, like
changing the gain. However, although a rather trivial and
straightforward design, it did turn out to be trickier than I
expected. For instance, if you take the feedback from after
the buffer and have two op amps, but only one of them
drives the buffer, what to do about the other one? It would
get the feedback for the wrong amplifier! That might cause
strange effects that might carry over to the active op amp
via the rails, perhaps. There are several ways to solve this,
but they all seem to need rather complex switching networks.
I have settled on using separate feedback networks for each
op amp, the active one closed around the buffer, the other one
closed around its op amp only so it will at least be well behaved.
Thus, I need at least 3 poles per channel. I have some 8-pole
switches lying around and plan to use one of them, but I have
to basically start from this switch when doing the layout.
Anyway, this is not meant to be a final amplifier for permanent
use, but a kind of testbed for experiments. |
| PRR |
That topology has a very bad name in "Pro audio". It is prone to act funny.
It does allow either output to be grounded, and preserves balance as much as possible, but that is not at all necessary for driving headphones.
I think it also has a low input impedance, which varies as you apply shorts to the output.
Just use noninverting + inverting modes, or a whatever with an inverter for the other side.
I'm not sure that sophistication has much to do with sound quality. (Yes, it can be fun.) |
| PRR |
> I have no opinion, not having read the HP article.
Those numbers appear to be mis-remembered.
Steven's walk-through in that thread explains it well (except I am not sure Shockley's relation and transistor Gm is familiar to all here). |
