diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
Trade: have heatsinks, wanted toroids - Click HERE for Original Thread
ACD
I've got four pieces of these heatsinks:
http://www.diyaudio.com/forums/show...&threadid=14299
which I didn't needed anyway. Have only been unpacked once!!
I trade for toriods: 220VAC primary/2x40VAC secondary,
300-1000W.......
Email me if you are interested.
panos29
I got from a previous incomplete Zen V4 project a 2X36V at 7A and 2X15V/1A primary 0-220-230V selectable. Total power 500VA toroid.
Panos
ACD
Hello Panos,
2x36VAC ????? Are you sure it's not 2x35VAC???
panos29
Yep, if you use the 0-220V primary the secondary is 2X37 and if u use the 0-230V you have 2X34V (unloaded). This was a custom job.
ACD
I think you mean 2x34VAC at 1x230VAC and 2x37V at 1x230V
:confused:
Sorry Panos. These are 5 to 6 VDC lower, than the one I need...
panos29
O.K, but just to clarify things on my side as I did not put it right the first time. I mean that the primary uses 3 cables, 0-220-230 so if you have 220V in your plugs (as I have) if you connect the 0-230 primary it gives you 2X34 if you connect the 0-220V it gives you 2X36 output. (just measured it)
Panos
ACD
Sorry but still 4 VAC (=5.6 VDC) below on each rail. I need +/- 55 VDC on each rail to match the other amps in bridged configuration!
Andypairo
Unfortunately the toroids I can source are 46VAC... :bawling:
Anyway, hope you find'em soon.
Cheers
Andrea
PS Let me know when the MJLs arrive...:D
Andypairo
quote:
Panos
Panos, are you willing to trade it with something (BJTs, caps, etc) ?
Cheers
Andrea
panos29
just state what you got in mind and maybe we can work it out. Thogh keep in mind its heavy enough and this means that postage will possibly be a bit "heavy" too.
Panos
Andypairo
What about continuing the dicussion privately? I don't think it can be much of interest for the other members...
As a starting point I think that we should give a "virtual" value to the items we are willing to trade, (also to postage, to avoid costly money transfers) and then make a proposal.
I'll wait for your email. (since I can't directly send you one)
Cheers
Andrea
ACD
Sold!;)
Thanks Martin from Denmark
Page generated in 0.040189981460571 seconds with 17 queries,
spending 0.01939750 doing MySQL queries and 0.02079248 doing PHP things.
Copyright ©1999-2009 diyAudio.com
