diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
This is my new work_A Series Linear Regulator - Click HERE for Original Thread
fwh1599
A wide-range (¡À5V-¡À60V)regulator design for use in headphone amplifier and its tiny size is also suitable for replace the power supply in CD player... :smash:
A 108mm*77mm Double side PCB
My work:
Look!The transistors of differential amplifier is thermal couping(Q03-Q04,Q13-Q14).
fwh1599
SCH Doc(.PDF)
peranders
No comments, not even from Fred :schratch:
I'll see that you have made some cross posting but it's still a neat CAD job. What shall you use it for?
fwh1599
Thank you.
Beacuse my English is very poor,I can't talk it very cleanly,Sorry.
I used it for modify my CD player and Head_AMP supply,I will use it for Pre_AMP.
Some cross posting for the Track (Electric to GND) is very strong.
I'm sorry my English is no good.:xeye:
fwh1599
Thank friends E-Mail to me,I answer some question here:
1,How to account Output Voltage:
VCC=2.5V*(1+R06/R05)
VEE=-2.5V*(1+R16/R15)
so you can change R06 and R16 obtain the output Voltage you need.
2,About R02 and R12:
R02/R12 limited the current passed LED01/LED11 is 2mA to 3mA.So R02=(Vin-1.65V)/2.5mA,the Vin is Voltage on C01,LED is red.as same as R12.
3,Diameter of C01/C11 in PCB:
the diameter is 35mm,and distance of pin to pin is 10mm and 17.5mm,so I can used 10000uF/63V in my work.
I'm sorry for my English,I wish you can understand,thanks.
Elso Kwak
Hi fwh1599,
I would use a current mirror to load the differential pair like in this picture:
Taken from http://www.metaxas.com/pages/masnewfiles/index.html
Click on do it yourself, then on CP-3 preamplifier.;)
fwh1599
Elso Kwak:
Thanks for your information.
Yes,it's a discrete regulator.
Although use a potentiometer to replace R05/R15,it will be alterable.
But I think potentiometer is precarious.After a half of year,Its value will change,and regulator output for audio is 5V(for digi) ,15V(for op ,etc), 35V,40V or 50V(for Amp) ,etc.During using,we needn't adjust it.
Page generated in 0.025896072387695 seconds with 17 queries,
spending 0.00695324 doing MySQL queries and 0.01894283 doing PHP things.
Copyright ©1999-2009 diyAudio.com
