diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
LM3886 gone crazy!! - Click HERE for Original Thread
soundNERD
I opened up the back of my subwoofer built using a lm3886 and noticed that a wire from the transformer had fallen off of the rectifier, leaving only 1 wire and the CT connected. Yet, the amp still worked. It was only getting either + and gnd or - and gnd, but it still worked. How could that be? I built the split supply version, but it was working off of a single supply??
-Mike
joan2
what happened there was that with one wire gone, you still had +/- rails because there is still one wire from the traffo and the ct going to the bridge rects, so you had a voltage-doubler in operation, what this meant was that the supply had a higher regualtion %, meaning the rails sag lower than with the other wire connected, less va from the traffo can be utilised in that case...
Page generated in 0.025208950042725 seconds with 17 queries,
spending 0.01292181 doing MySQL queries and 0.01228714 doing PHP things.
Copyright ©1999-2009 diyAudio.com
