diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Simple amp with DC on the output... - Click HERE for Original Thread
SkinnyBoy
I made a simple amplifier today.. and for some reason when I have nothing connected to the input I get a positive voltage on the speaker output.. :hot: why ohh why??
heres the circuit.. something I missed?? something I don't need? thanx.. I am using +-24 volt rails BTW.. and 2 chips share a common transformer and 10,000uF per rail... no caps close to the chips, the closest are the 10,000uF which are only about 5cm of wire away anyway... any ideas about the voltage?? THANX!!!
Christer
Yes, there is something you have missed. Input offset voltage
and current.
A resistor to ground on the positive input will lower the DC
level when no source is connected.
The value must be a trade-off, since it will also lower
the input impedance of the amp.
You may still get problems with output DC both with and
without a source. I recommend a capacitor in series with
820 Ohm resistor. About 47uF should do, unless I miscalculated,
but let's make it 100uF.
Netlist
What opamp did you use?
/Hugo :)
Circlotron
Put a cap of maybe 100uf from the bottom of the 820R resistor to ground instead of to ground directly. This will reduce the dc gain of the cct to 1. Also, the input should have some resistance, say 47k, from input terminal to earth to stop it drifting when open cct.
peranders
Is the input floating or have you tied it to ground? The IC must allways have DC-paths from the inputs to "somewhere" (ground). If you not have bias currents you will get a "undefined condition".
He, he, three people were equally fast as I.
Opamp? Probably LM3886!
SkinnyBoy
quote:
/Hugo :)
LM3886
quote:
Will try that sometime...
quote:
Originally posted by peranders
Is the input floating or have you tied it to ground? The IC must allways have DC-paths from the inputs to "somewhere" (ground). If you not have bias currents you will get a "undefinened condition".
huh? lol
peranders
Benrangelpojken, how much offset? It helps if you tell us that.
SkinnyBoy
quote:
and current.
when did you post??
anyway... I was planning on running this directly from a computer soundcard with no volume control.. is there a problem with this?
I believe just keeping this connected to my source should prevent me from getting the positive supply rail on the output.. :hot:
Christer
quote:
Originally posted by SkinnyBoy
when did you post??
I had a feeling you would start this thread, so I answered a
couple of minutes before you asked the question. ;)
Considering computers crashing and programs running amok,
I would say a pot might be useful so you can turn down the
volume if necessary. Actually, a pot at the input will serve as
the grounding resistor as well, so go for that. A 47k log pot
would be fine.
SkinnyBoy
+23 volts offset.. lol
which is why I wasn't calling it offset.... I think I just need something on the input... I don't want a pot... and I am not sure what the computer soundcard does while the computer is starting up.. I am also quite sure that 4inch woofers don't like 23volt applied to them.. lol
li_gangyi
dude...did you put a resistor before testing for offset??
SkinnyBoy
would be fine.
HAHA very funny.. :P lol
I CAN"T use a pot... this is my computer in a CD player case project.. the case has to still look like a cd player... nothing added to the front... :) its going to have an inbuilt 30watt per channel amp.. lol
http://diyaudio.com/forums/showthre...3905&highlight=
SkinnyBoy
quote:
of course not.. lol
my concern is the fact that I want to use the computer to control the volume and if there is nothing connected I get the voltage rail on the output... the amp will not be able to be on without the computer... but I still don't know..
BobEllis
You should consider some sort of muting for power up/down of the computer and/or a blocking cap on the inputs.
I connected my computer directly to an amp and there are huge pops on startup, especially after it locks up. (sometimes an hourly occurrence). I have a Dell Inspiron 8200. Other computers/soundcards may behave better, but why risk your speakers?
Christer
You still ought to have that resistor to ground at the input.
You should also be aware that there is now nothing that
protects your speakers from DC in case of amp failure. If you
care a lot about you speakers you may wish to include some
form of DC protection circuitry or, in the worst case, a cap
at the output.
millwood
if you are getting that big of a DC offset, I would suspect the wiring.
SkinnyBoy
yeah... true..... I considered a delay speaker connecting thingy.. lol
or... I am going to have a line level out.. that will also connect to the amp.. I could make an external box with a pot that connects the output to ground.. yes? :)
SkinnyBoy
at the output.
AHHH!!! STOP REPLYING!!! lol
yeah... but caps are big.. lol a 50volt 2200uF cap just takes up too much valuable space.. lol :D hehe
BobEllis
I meant when the computer powers up it sends some DC to the amp. The amp I use here (Hafler 500) has a speaker protection delay that includes DC offset protection. It is not fast enough to prevent the pops, it mutes after the noise then reconnects after a few seconds.
SkinnyBoy
Perhaps I'll just put a pot on the back of the case.. lol there really isn't any room though... :rolleyes:
li_gangyi
If you dun wanna use a pot...use a 50K resistor and tie it to ground...and remember to attach an 8ohm power resistor before trying to measure any offset...
SkinnyBoy
hmm... ok.... and perhaps a capacitor on the outputs.. :) just to be abit safer... and maybe a.... umm.. I forgot what I was saying.. :xeye:
carlosfm
Hey SkinnyBoy,
As Christer said, you NEED to put a resistor (say, 47k) on the RCA inputs (from + to ground).
If you don't have a pot, you need this.
DON'T CONNECT THE AMP TO ANY SPEAKER BEFORE DOING THIS!!!:eek:
23v DC offset may kill any speaker.
Oh, and you should put an input cap.
It's not big.
Nothing on the output.
Oh, BTW, don't put water on this one.:bawling: :clown:
li_gangyi
Yeah...same thing as I said...though I suggested 50K...might not be available though...
SkinnyBoy
quote:
Originally posted by carlosfm
Hey SkinnyBoy,
It's not big.
I already connected it to a speaker... an old 4inch driver.. and unpluged the input.. lol
li_gangyi
Ok..check for a missing rail...one side might be gone...or shot..therefore the offset...
carlosfm
:D
No Bang?!:eek:
Good speaker, man, lol!!!
peranders
Skinnyman, have you made any troubleshooting?
1 Connect exactly as the schematic
2 Check the component values
3 Ground the input via a 10-47 k resistor
4 Connect nothing to the output
5 Measure all voltages with a DMM. Post the result to us.
6 Read carefully the datasheet and AN-1192
7 Take a photo of it and post it here
With the connection you have chosen you will get less than 300 mV offset I'll guess.
Skinnyboy, we talked about learning in an another thread, this LM3886 happens to have an excellent application note and I think you should read it carefully and try to understand it. DC-paths for the inputs ARE ESSENTIAL! If you don't understand why, just trust us. Meaning you must have a pull down resistor when you test this amp with no signal source. It's also wise to have all times just case the amp is switched on and the input is disconnected.
SkinnyBoy
:D
No Bang?!:eek:
no bang... the speaker cone went in about 3mm, and sat there hovering....
I haven't connected the resistor yet, ok? it was like midnight... :rolleyes:
1. The circuit is connected correctly
2. I chose those component values at randon (well, almost) as I didn't have the ones in the diagram...
3. I shorted the input to ground (with the CD players output) and measured about 45mV ofset
my digital camera is rubbish... I'll take pics anyway.. everything is once again mounted across the chip.. :)
Thanx for the help.. I'll connect a 47ohm (I probably don't have any) resistor across the input...
Christer
Probably just a typo, but in case it wasn't, the value shoould
rather be 47 kOhm.
SkinnyBoy
rather be 47 kOhm.
It wasn't a typo.. 47k? thats pretty high.... I'll use something lower... closer to 10k :)
soundNERD
I didn't have time to read all of the responces, but in the ones I read, I saw nothing related to the simple fix.
You said that the output voltage increases when an input source is connected. Portable and cheap CD players tend to put out a voltage in the output. I had the problem where when the CD player is turned on, the speaker would suck in about 1/2 inch then come back out with a pop sound. To fix it, I just placed a small cap inline with the input. I myself used 2uf. It solved the DC voltage problems.
Good luck, Mike
SkinnyBoy
Good luck, Mike
nah.. theres nothing wrong with it.. just my lack of electronics knowledge... lol...
Christer
Probably works fine. My soundblaster card has no problem
driving headphones from the line output (not sure if that is
advisable, though).
However, you were very reluctant to put in the resistor at
all, and now you want a low value. A 47k is closer
to no resistor at all than 10k is.
SkinnyBoy
33k it is.. lol cos they are prettier.. :D
Christer
Maybe, if the bottom colour is blue, otherwise I can think of many
other more estethical values, to my taste, that is. :)
li_gangyi
Should be ok after you got the 47k there..or at least a pot...
carlosfm
Definitely.
The sound card is always to be kept at max volume.
That's because you loose 1 bit of resolution for every 6 db of digital attenuation.
SkinnyBoy, if you care about sound quality, put a pot on the amp and control the volume there.
Let the sound card at maximum volume.
:angel:
SkinnyBoy
Definitely.
:angel:
my soundcard clips at maximum volume!! HAHAHA!! and anything about half way gets distorted... lol
I could always put a pot INTERNALLY... so.. the max volume on the soundcard is the max level I would listen to it (or the "normal" level, or the level at which the amp clips.. lol)
li_gangyi
Dude...what kinda sound card have you got there?? Seems that mine does not clip at max...
peranders
Does it work now? 45 mV is very good!
SkinnyBoy
The soundcard that clips badly is the one in this computer, not the one I am using for this new project... the clipping card is an old ISA card.. I believe it has an inbuilt amp that causes the problem..
I dunno if its 45mV it was before I connected a resistor to the input.. it wasn't a proper measurement.. (I don't think) but I can't test it again as I am working on installing it in teh case.. :)
carlosfm
lol crappy lol soundcard.:D
Not good for testing.:rolleyes:
lol.:cannotbe:
SkinnyBoy
Some pictures of stuff...
:D
SkinnyBoy
Please sir, have another.. :p
SkinnyBoy
JUST TAKE THE STUPID PICTURES!!!
SkinnyBoy
I wasn't going to waste my ISPs bandwith hosting these pictures.. and slowing my internet connection down... :p instead I chose to host them by the only website I visit, to slow that down instead.. lol
carlosfm
Nice, lol.
It only lacks a picture of it's face.:clown:
I like to look gear in the eyes, lol.:D
Where's the front panel pic?:dodgy:
SkinnyBoy
well.. theres none in the original thread.. lol
its just a standard CD player... nothing special at all.. :) well.. not from the front anyway.. and it will look like a standard CD player when finished.. (Except probably a few air holes in the top.. lol)
li_gangyi
Looking good...maybe you might wanna consider another soundcard...
SkinnyBoy
this soundcard is inbuilt.. I was talking about a different one, in a different computer.. :) sorry for the confusion..lol
li_gangyi
try reducing the level of output from ur soundcard...some members here might be able to help...or maybe remove the "amp" section from the sound card...
peranders
It's possible the reduce the gain of the LM3886. Much easier :nod:
SkinnyBoy
would you just shutup about the sound card.. :rolleyes: if it makes you happy, I have swapped cards now.. happy??
sss
well , a cd player+amps+motherboard and processor in one box :)
it was easier to put the amps inside the pc case , dont u think?:)
it looks better this way though :)
li_gangyi
Ok...so you swapped the soundcards...guess the amp now works properly now ?? And no DC on the outputs...
SkinnyBoy
I'm not even going to answer that, the question doesn't even make sence....
li_gangyi
I mean...does the amp work properly now?? And without DC on the outputs...
SkinnyBoy
I still haven't tested it with the changes...
carlosfm
Just don't test it with your Grand Utopias.:D
SkinnyBoy
I tested it.....
less than 150mv with just the resistor on the input...
and
less than 50mv with the computer connected to it.. :)
li_gangyi
great...so are you satisified with the final product??
SkinnyBoy
the heatsink is too small... it gets too hot... and I still haven;t added a cap to the input for DC filtering... I haven't blown the cones out of the 3inch woofers its running YET, but if I'm not carfull I probably will...
there is no way I could use this to run 4ohm speakers.. the heatsink is far too small... I might try and fan cool it or add some fins to it.. but space is really a problem...
li_gangyi
try water cooling...might also help the PC you are building this thing in...
SkinnyBoy
umm.. there is no space to water cool it..... it gets too hot to leave your hand on it.. lol
li_gangyi
hmmm...how about lifting the amp outta the PC?? or maybe free up a drive bay and use the whole space for a heatsink...
SkinnyBoy
the 3inch woofers cost $9 for the pair... they are sortof TLs.. they are sitting on my desk facing up with a 50cm piece of pipe resting ontop.... they have a usable response down to like 50Hz..... but not at too much power...
the amp cost me $2.70 to make (even cheaper than the speakers) all I had to buy was the speaker terminals...
EVERYTHING else was recycled, except the chips with are samples.. :)
SkinnyBoy
did you even read previous posts and look at the pictures?
li_gangyi
I did...maybe a thicker aluminium extrusion would help...how about a thick aluminium block...drileed and with fans at one side...to help dissapate heat...or attach some fins...
SkinnyBoy
I suppose I could at a PINCH bolt another piece of aluminium onto the back of the current heatsink, and bend it so it goes over the network card...
li_gangyi
wonder if it's enough for the amp...relocate the amp to the sides...and have heatsinks extruding out of the case?? Izzit a possibility?
SkinnyBoy
the amp has to stay where it is...
there is nowwhere else for it to go, and where it is the mains wires, and secondary connection to the transformer are as short as possible... :) as is the DC from the filter caps and bridge... :)
carlosfm
Hey Skinnyboy,
Even staying where they are, you have some space to put the chips on cpu heatsinks (with fan).
It may be tight, but I think it's manageable.
Fans working at low speed (lower voltage) don't make much noise and are effective.;)
lol.
SkinnyBoy
hmm.. I don't think I do have space.. lol the aluminium plate they are mounted on now rests on the motherboard, and the top of the case.... and, the surface that the chips are currently mounted on is only 4.5 cm high....
li_gangyi
that is really too small...will your mini PC have a cover?? Perhaps you can use a big heatsink as a cover..
SkinnyBoy
umm.. yes.. it will have a cover.....
no.. the cover can't be a heatsink...
li_gangyi
groans...how do we cool the amp then??
SkinnyBoy
we don't.. if it overheats.. it overheats... no big problem...
carlosfm
Naughty naughty, I see that you changed some things.:whazzat:
Your picture is from version 1.0, and now you're on version 1.1.:bawling:
Is the new version better?
Well... at least it's:hot: .
SkinnyBoy
umm.. no.. its the same... I'll remove the word "now" from the post you quoted.. (not literally)
carlosfm
Don't tell me you can't fit some heatsinks or cpu coolers in this space.
I see some space here.
:smash:
SkinnyBoy
:smash:
that gap is like 3.5cm X 4cm X 16cm perhaps a heatsink.. but NOT a CPU cooler... yes.. I can fit SOME heatsink in there.. and I will try...
carlosfm
One single PentiumII cooler (with fan) would fit there.
If you can find one.
And it would do fine for the two chips.;)
li_gangyi
yeah was thinking of that as well...
SkinnyBoy
umm.. no it won't....
carlosfm
Yes it would.
You may have to cut a little of that l-shaped aluminium so that the fan fits, but it would do.
There are (were) some thin PII coolers, about 2cm thick (the heatsink), and about 1cm more for the fan.
Remember, hot chip means problems.
As you have it, you can't play your music loud, the chip will protect itself against destruction.:D
lol, and when the music is good, turn up the volume!:)
SkinnyBoy
Yes it would.
it won't fit...
li_gangyi
...you just gotta get a heatsink there pal...
Page generated in 0.23908996582031 seconds with 17 queries,
spending 0.07303429 doing MySQL queries and 0.16605568 doing PHP things.
Copyright ©1999-2009 diyAudio.com
