diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Anybody seen this one? - Click HERE for Original Thread
Duo
Well, here's a jab into the knowledge of the tube guys!
I am pretty sure that this picture is of a tube, but correct me if I'm mistaken.
I found this nifty little device in a bin of diodes at the school electronics shop. I cleaned it up a bit and found that it's made by General Electric. It has some numbers on it: GL-6299 which is probably the type. There's another in kind of lopsided print: 8854 which seems like it would be a serial number of some sort.
Has anybody seen this device? Can you verify whether or not it's a tube or what type it is if so?
zzz
http://hereford.ampr.org/cgi-bin/tube?tube=6299
Sch3mat1c
Aww I just typed a reply and then stupid Acrobat plugin crashed IE. :dodgy: Anyway I was gonna say:
Looks like a 'lighthouse', or planar triode.. lesse if ol' Frankie has any data... Ah:
http://www.mif.pg.gda.pl/homepages/.../149/6/6299.pdf
Doesn't look good for much besides its intended purpose...
Tim
li_gangyi
This thing looks like a mini Klystron or a high-frequency valve...not so sure though...
Duo
Quite interesting. When I found this I had no clue what it was, but by looking at it closely, I found that there were enough pins for it at least to be a triode and the it seemed to be shaped like some sort of tube.
I guess I'm good at observation?:cool:
Well, good to know what it is so I can use it in my next project.
It will make an excellent tube in a UHF radio for a gainstage or oscillator.
li_gangyi
so what are u planning to do witn it?? seems preety hard to break in that package...
316a
Good luck finding the sockets ! If you do try to use this thing remember that the contacts will be exposed if mounted on top of the chassis . The problem with UHF valves is that they seem to like to oscillate on their own , may be problematic trying to implement , not just for the socket issue . Curves look nice though !
316a
Duo
It'll be no problem. I'm good at fiddling with tubes so I'll make it a socket or find one somewhere.
I'll build a circuit for it and if it doesn't work properly, I can always modify it.
It's interesting just to see something like that in operation, would be a cool tube to see on the top of an open chassis.
dhaen
..snip would be a cool tube to see on the top of an open chassis.
It would indeed look very strange. That valve is a disc seal triode designed to be mounted in a cavity. In normal service, it'd never be seen.
Bear in mind that this class of device relies on conduction cooling through the clamps that fit the rings, but in this case, being only 2W, it may not be a problem.
Enjoy ;)
fdegrove
quote:
Enjoy
...Your latest oscillator?
Planars are definitely the worst kind of female to work with...
Like most members of the opposite sex they look cute enough though...:D
Cheers,;)
Page generated in 0.035576105117798 seconds with 17 queries,
spending 0.01091409 doing MySQL queries and 0.02466202 doing PHP things.
Please support our sponsor.
