diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Whispering and Rustling Leaves - Click HERE for Original Thread
maynardg
I just finished a 6SN7 SRPP preamp. My question is: What is the cause of a soft whispery, rustling leaves, wind in the trees sound?
I have not heard it before. Ideas appreciated.
Thank you.
MG:confused:
wd40
Is living I the copy also possess the same appearance on MATTSSE Preamp , I also want to realize the reason .It is one kind of very slight ' Si ' voice ? :scratch:
jean-paul
Could it be that it picks up radio signals ? Please post a schematic, it'll make things probably clearer.
maynardg
I'll try again.
Paul Barker
oxidation on valve base/pins dry joints.
Sch3mat1c
Hmmm... I think I've heard that before in Frankenhouse... lemme see if I can find the faulty 6U8 that did it...
That one's not it... although the triode section is missing the heater... I wonder how the heck that one got past QC! :eek:
Ah, here it is! Lemme get out the mic...
Damn! Now it doesn't want to do it... argh...
Hey, it's working now! I'll try editing the sound bite a bit and see what I can do...
Tim
316a
quote:
Originally posted by maynardg
I'll try again.
Hello ,
This could be due to internal leakage or heater to cathode insulation . Are you using the same tube for both voltage amp and SRPP load ? If so it may be advisable either to float the heater at half B+ or to use separate tubes : one for voltage amp (heaters ref'd to 0V), one for SRPP (heaters ref'd to half B+) . Some tubes are better than others with regards to internal leakage , you could always try other tubes which may be a quick fix . Hope this helps :)
316a
ShiFtY
I agree, try referencing your heaters at 100V, (obviously disconnect them from ground first!)
Raj1
I accidently caused a short on the 317t that supplies 2.78 volts to 2 3a5 filaments, the short was due to a solder blob. I was bypassing the adj resistor to improve the performance of the reg. Unfortunatley I onlty noticed I had done this when the tubes were glowing bright red.....
I have fixed the problem, but I am now getting a rustling sound. I have checked joints etc, could it be that the tubes are now damaged, as they worked fine before the short........
Raja
Page generated in 0.024986028671265 seconds with 17 queries,
spending 0.00690818 doing MySQL queries and 0.01807785 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
