diyAudio.com diyAudio Forums Archive > Top > Source > Digital
CD60 problem - Click HERE for Original Thread
guido
Well,
Thought 4 players would be too much, but...
Picked up a CD60 (marantz) for 15 euro. Playing and not one scratch on it..... No work done inside too.
However, there is a catch: the guy said it would stop or give problems when it played for a while. Not experienced that yet.
However, there are three parts of the display flickering from the part used when recording to cassette (all the time during normal playing): the A,B and text above. Randomly flickering.
Also the first digit of the minutes has some segments flickering.
Now and then some other digits flash on for a milisec.
Well, i did the obvious: resoldered both controllers and the display. Also the ps regulators. Still the same.
The guy who sold it brought it for repair. Told him it was one of the controllers (could well be, there is not much else which can be broken).
Anyone:
- seen this before?
- has a service manual/schematic?
- has a spare controller (dont lauch, picked up one for my 650)
maybe even CD50
Seems the main pcb is equal to my cd40, only opamps differ (5532 instead of lm833 IIRC). And the motorpot is extra.
So i tried the obvious: swap the fronts. But that did not work.
Communication between main and display controller must be different in 60 than 40.
This thing is perfect for my dac (transformers ordered). much more room than my 650. And i have plenty of cdm4's. 2 second hand an 3 from pollin (Till did not get all :-)
Going on hols for a while, maybe i wont react here soon.
Thanx in advance,
GuidoB (!=GuidoT)
guido
Eh,
I meant that the guy brought it for repair somewhere and that they told him it was one of the controllers. He found it too expensive to get the controller replaced. Then he sold it to me.
And i meant that i could maybe even use cd50 parts. Display is equal, just some features less i wont use anyway.
Getting late,
GuidoB
Bricolo
Does it look like my CD62, internally?
http://www.diyaudio.com/forums/show...&threadid=20592
guido
Think it is different after the 7310, i have the 7220 and 1541 behind it. But the controller 'talks' to the 7310, so that part and the front part might be quite similar. If you have anything on it, i would be interested.
Thanks,
GuidoB
Bricolo
quote:
Thanks,
GuidoB
Does it have the same 2 boards topology?
carlosfm
Hi Guido.
It can be a display problem.
Those fluorescent displays are not ethernal.:bawling:
If you have a spare cd player with exactly the same display (even if the control circuitry is different) you may give it a try.
Bricolo
Yep; I also thought about this
On some of my old (5-10 years) sutff that uses VFDs, some characters or some bars aren't as luminous as the others. I can't tell if they are the most of the less frequently used ones, but some are clearly less luminous.
Maybe flickering is the next stage, before self distruction. I hope not
guido
Yeeeeeeeeeeessssssss!
I talked to some people who work here at philips (heerlen) were they design displays (mostly lcd). They said that such a display works or it does not (the segments that is).
So i looked a bit further and found that the display is controlled by a telefunken chip: the U3090. And that the controller in my cd40 is also this 3090. So i took the chip out of the cd40 and into the cd60: it solved the problem.
So in the end i got a cd60 for ~45 euro's, cause that is what i paid for both players. And the cd60 looks like it came out of the box only yesterday. No scratches or anything.
i'm happy!
GuidoB
Fin
I picked up a CD60 on eBay for AUD$72 = 42 Euro. It seems to be in quite good condition - plays CD's, CDR's and CDRW's. Probably doesn't look as good as Guido's as it has a few scratches here and there. The inside looks good and hasn't been worked on.
The only functional problem I can find with it is also a display problem. The left side of the display is less intense or luminous than the right side. There is a gradual increase in brightness from left to right.
Does anyone have ideas about this display or is it time to replace it (or turn it off completely)?
Page generated in 0.03178596496582 seconds with 17 queries,
spending 0.00696015 doing MySQL queries and 0.02482581 doing PHP things.
Copyright ©1999-2009 diyAudio.com
