diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Stax SR-34 black box - Click HERE for Original Thread
Jennice
Hi folks,
Does anyone know what is hidden (apart from a transformer) inside the black box that comes with the Stax SR-34 electrostatic headphones? :scratch:
If possible, schematics would be nice to have...:nod:
Jennice
analog_sa
There must be a diode multiplier for the polarising voltage. Sorry, haven't really looked. I had Stax in my 'junior' years when i believed opening boxes was bad :)
Brett
Peter is pretty close with what's inside one. If you have a unit, open it and trace it out; should take 2 minutes.
I had one of these 20 years ago before upgrading to the Lambda range (which I still use).
Jennice
that's what I did.
The rotary switch (speaker/earphones) needed cleaning desperately, so I took and opened the mysterious black box. Man, was I dissapointed !:eek:
They made us pay all that for the twp connectors, a rotary switch, and two pathetic small transformers with thermal resistors (for safety I suppose) on a PCB!
There is not even a bias voltage. I learned elsewhere that some of them have the static charge on the foil which decayes ower the years, after which you'll need service 'sob*
TWO transformers... *pout*
Well, so much for the mystery... :bawling: :bigeyes: :bawling: :bigeyes:
I guess this pretty much settles the topic...
Jennice
analog_sa
The ones that don't require bias votage are electret, not electrostatic and have always been the cheap range of Stax AFAIK.
Petter
You are all correct, but you should consider heading over to http://headwize2.powerpill.org/projects/index.htm for an interesting read.
Petter
Page generated in 0.020246028900146 seconds with 17 queries,
spending 0.00665426 doing MySQL queries and 0.01359177 doing PHP things.
