diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
DIY IR remote volume control addon - Click HERE for Original Thread
emorysmith
I would like to build a remote volume control for my older (non home theatre)
receiver. The audio/vca/motorpot section is no problem for me, I just can't find info on
the IR receiver/decoder section. There are IR receivers available at Radio Shack
but info on how to interface and program them escapes me.
Goals:
1. To be able to be controlled by an inexpensive universal remote using the
"Audio" button on the remote. Ideally, it would mimic a known home theatre
receiver so that I could just program the remote by holding the "Audio"
button and entering a three digit code.
2. To power up in a sane mode. Volume at 10% or so, NOT 100% or mute.
3. LED bar graph for gain/attenuation indication.
4. To be an external unit connected to the receiver's eq/processor loop.
No problem here. I have elex fabrication facilities.
If I get it going, I'll post link to complete info.
Thanks in advance for any info,
Emory
Tubeee
Ask Weeder Technologies,
http://www.weedtech.com/
Terry Weeder has a simple solution, but I don't know if his project or products still selling.
Kay
hy Emory
look at Philips Semiconductor for SAA3009 or SAA3049 (RC5-Receiver)
If you need a schematic for using the SAA with a motor poti, send me your email-address.
best regards
Kay
mcs
quote:
Originally posted by emorysmith
[B]I would like to build a remote volume control for my older (non home theatre)
but info on how to interface and program them escapes me.[/QOUTE]
I just designed a remote control receiver some months ago - have a look here: http://stiftsbogtrykkeriet.dk/~mcs/Remote/index.html
[QUOTE]Goals:
I've used Philips RC5 code, which should work with all universal remotes
If you use a motorpot it will power up in the (in)sane position you left it in :-)
Is that nescessary for a motorpot?
I am also working on a remote controlled "passive preamp" as well as a board with relay or chip attenuators, but that's not complete yet...
Best regards,
Mikkel C. Simonsen
mcs
quote:
Goals:
Best regards,
Mikkel C. Simonsen
mcs
quote:
Originally posted by Kay
hy Emory
Kay
Aren't those Philips chips obsolete? Can you still get them?
But it only took me a couple of hours to make my own replacement chip using a microcontroller ;-)
Best regards,
Mikkel C. Simonsen
Kay
hello Mikkel
This is correct, but I have four.
This is also correct, but can Emory do it?
Best regards
mcs
Perhaps not, but I could make him a chip. And many others could as well.
Best regards,
Mikkel C. Simonsen
emorysmith
Here's some great info:
Pre-programmed PIC. Reads Sony RC. Has 4 or 8 momentary and toggle outputs.
http://www.pics.com/~grieb/IR.htm
I'm in progress of getting parts together.
Using relay on a toggle output for mute.
Using motorpot on momemtary outputs for volume.
http://24.92.73.209/pix/irvolcont.pdf
Might change daily. (As might the IP :-( )
Yes, the LM18200 H-Bridge is overkill but
I have several ;^)
Kay
Why you don't make your own controller?
Bascom is free for 2kb (Basic-Compiler for AVR, use the AT90s2313)
JasonL
this is looking interesting. you could use this Circuit for a alps Volume Control..
BrianGT
I had this same idea a while back, but never actually did it. If anyone is interested in this, you can get dual gang 50k audio taper motorized alps potentiometers from www.brigarelectronics.com part number 50KAX4 for $5.95 It is quite a good deal, and much cheaper then the other prices that i have seen for these potentiometers. I bought a bunch of these potentiometers a couple of months ago, and they are nice parts.
Brian
mcs
quote:
Is it actually a dual pot? The picture looks like a quad pot...
It's a VERY good deal - they normally cost $45-50 here (Europe).
Best regards,
Mikkel C. Simonsen
Bob Grieb
For anyone interested in the TinyIR learning IR receiver (8 pulse or level outputs) or in a learning IR transmitter IC, my web site has moved from www.pics.com/~grieb/IR.htm to www.tauntek.com Thanks, Bob Grieb
Andypairo
Brian
Brian, since you have bought them, can you confirm if they are dual (stereo) or quadruple pots?
Cheers
andrea
DragonMaster
http://home1.stofanet.dk/hvaba/fprc5rx/
pots:
http://www.blore-edwards.com/
I don't know them, but might be interested to make them build some custom pots for me.
John Hope
The Kodenshi remote control receiver IC (Farnell 139-877) is a simple 3-terminal device that takes care of all the IR detection and amplification and really works well over a wide angle and a good distance.
Holtek make TX and RX chips for IR remote control. (Available from Maplin in the UK). They're cheap, dead simple and suited to basic applications, but for some reason I couldn't get the receiver chip to work at all. Maybe others will have better luck.
The Holtek transmitter requires hardly any external components and works as advertised. The modulation uses a series of short and long pulses to represent 1's and 0's, which means you can make your own decoder in a cheap CPLD (eg Altera EPM7128S) I can supply VHDL code for anyone interested in this.
Then when your proto works, you can go buy a neat 'learning' remote and program it from the Holtek transmitter.
Hope this is of help
John
jleaman
Any one build one yet ? im looking to buy a board now with a small remote to control my motorized alps pot's..
Page generated in 0.058902025222778 seconds with 17 queries,
spending 0.00890517 doing MySQL queries and 0.04999685 doing PHP things.
