diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
BOSOZ PS Question - Click HERE for Original Thread
vdi_nenna
The original project calls for one power supply board for both channels. Has anyone used 2 PS for the project?
Or, are 2 PS boards not nessecary?
Thanks,
Vince
nobody special
I haven't built one personally yet, but when I do I will use two regulator boards, if not two seperate transformers- one for each channel. It's just a way to get better channel seperation- a "dual mono" approach.
Nelson Pass
As long as the single supply has adequate current, there
is no reason you can't use it.
stefanobilliani
As an experience with BOZ preamplifier , an extra filtering portion in the original circuit is a nice thing , and it produce good results . I find it here http://apu.freeshell.org/pre.html at the mid bottom of the page click to enlarge the PSU image.It is an experience with BOSOZ from an Italian guy.
Roberto Amato
I used two PSU with much larger condenser banks. The difference I found between the single PSU and a double one is a slightly better imaging and detail in favor of the double PSU. The single one, anyway, was adequate to drive both channels.
ciao,
Roberto Amato
lgreen
To answer your question, you only need a single power supply board, it provides sufficient power to drive both channels. However, you will find that people around here make two boards to go dual mono. I have also done this but it certainly is not necessary. You could also increase the capacitance or make other modifications to suit the result you want.
Page generated in 0.029984951019287 seconds with 17 queries,
spending 0.00794768 doing MySQL queries and 0.02203727 doing PHP things.
