diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
About The C1 & C2 of Zen V5 - Click HERE for Original Thread
Peleus
The value of C1 and C2 in Zen V5 is 47uF, and one friend of mine question the value that " will these high value limit the low frequency?" "Can I instead with film type capacitors with 4.7uF?"
I can't answer these question!
Please help me and any comments will be welcome!
Thanks!
joensd
According to the formula Xc=1/(2*pi*f*C) the frequency depending resistance of C1 and C2 gets lower with higher capacitance value.
That´s why most input capacitors of audio amps have relatively high value : To pass low frequencies with greater amplitude.
But IMO 47uF is plenty and you should get away with 4.7uF.
Jens
Nelson Pass
4.7 uF will work, but you will see a rolloff around 5 Hz or so.
Peleus
Thanks Joensd and Nelson Pass!
But I still feel confused about the reply of NP! If we will see a rolloff about 5 Hz, it seem OK! No one can here the quite low sound, right!
Is there any mistake? :scratch: :scratch: :scratch:
Page generated in 0.019608020782471 seconds with 16 queries,
spending 0.00907969 doing MySQL queries and 0.01052833 doing PHP things.
