diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Denon AVR-1403 Pre-out's - Click HERE for Original Thread
Jennice
Hi everyone,
Does anyone know how / where to find the line level signals inside the Denon AVR-1403 Surround receiver, in order to make DIY pre-out connections?
Best Regards,
Jennice
Jennice
The case is closed for the time being...
I found out that all ine I/O's and the speaker terminal "negatives" share common ground reference. Therefore, the case is solved to my satisfaction by creating a simple resistive voltage divider to mount on the speaker output, and connect it as a normal line source to my existing equipment.
Jennice
Page generated in 0.016222953796387 seconds with 16 queries,
spending 0.00796866 doing MySQL queries and 0.00825429 doing PHP things.
