diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Correct XLR connections? - Click HERE for Original Thread
dantwomey
I'm putting together my Aleph 5 and I'm wondering what the correct connections are for the XLR connector. The connector (as seen in the picture below) has a tab connected to the frame of the connector and pins 1,2, and 3. Traditionally, which pin does +, -, and G go to? For added clarity I've included the power supply diagram I'm using.
Dan
JOE DIRT®
pin 1=+
pin 2= -
pin 3= ground
tab= ground
trwh
Hi Dan
In this pic, you can see that pin 2 is hot (+), pin 3 is cold (-), and pin 1 is ground.
Hope this helps,
Tim.
trwh
Oops, Joe posted while I was composing, and my pic didn't come out clearly. Visit this page for a better look:
http://www.rane.com/note110.html
Also, I notice that our advice isn't the same - with respect the Rane site will be correct. :)
See ya,
Tim.
dhaen
Tim is quite right. That is the most commonly used connection format, and the industry standard for balanced connection.
Page generated in 0.024322986602783 seconds with 17 queries,
spending 0.01000905 doing MySQL queries and 0.01431394 doing PHP things.
