diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Locating diodes close to the M3875 - Click HERE for Original Thread
grege
Hi all,
I have see a few examples of people locating the diodes close to the chip rather than close to the transformers.
I was wondering the pros and cons of such an idea.
analog_sa
I don't think diode location will make any difference.
cheers
peter
Mad_K
quote:
Originally posted by grege
Hi all,
pros: dunno
cons: higher impedance between the transformer/rectifier. This could make some unwanted effects in your PSU.
Nuuk
Probably down to space constrictions but I would prefer to keep these items as far away from the signal as I can!
Peter Daniel
I built separate supply for my phono stage and decided to use diodes on main board and only the transformer in a separate enclosure. The wires from transformer were probably 3 feet long (4 per channel) and when I used to run them close together (in a one sleeve) they got really hot. Had to remove sleeve and had the separated.
I would imagine that it's always better to have bridges closer to transformer, with some local caps (I'm using 4.7u BG N), and run DC to the amp. Any possible AC noise is reduced this way.
analog_sa
Can't think of any reasonable explanation for that. Poor insulation led to a short?
Peter Daniel
I didn't measure any short. But the cable was made out of Audioquest speaker cable (Midnight, IIRC). It was warm to touch. Later I used 8 pcs of teflon insulated, loose run wires and it was fine.
goudey
Audioquest speaker cable....
"...and when I used to run them close together (in a one sleeve) they got really hot. ..."
"...the cable was made out of Audioquest speaker cable..."
An interesting and sometimes important note on some of the Audioquest speaker cables: The cable is made up of individually "insulated" solid core conductors. The conductors have different color insulation, but often there is more than one wire with black "insulation". If you use an ohm meter to measure resistance BETWEEN "insulated" conductors, you will discover that the black insulation does not insulate (somewhat conductive). That could explain the mystery of the hot cable when used to carry signal between two black wires.
grege
Thanks for the responses.
quote:
What effects would you imagine besides a little voltage drop due to resistance.
quote:
The AC to the rectifiers would be say 22VAC @ 50 or 60 Hz, but the AC ripple after the rectifiers would be a few volts? @ 100 or 120 Hz or do those small 4.7uF caps actually remove all the ripple. What is the predominant factor for AC noise, voltage amplitude or frequency?
Peter, so you are using 1000uF BG at the LM3875 and 4.7uF BG at the rectifiers. Have you found this really necessary? I was wondering if the long power cable was acting as a resistive element in an RC filter thus help smoothing the PSU.
Nobody has mentioned the noise from the diodes switching. Is this significant?
Peter Daniel
quote:
It is indeed the case. I measured something like 120ohm between some of the black wires, I know there was no short, but I have no clue where this comes from. It may indeed be the reason for cable getting warm.
My cables are 2' long and this is how I use the caps. I'm using those small 4.7u BGs as they improve sonics. It was also suggested to me by Fred to use some capacitance with the rectifiers. I tried what I had on hand and I liked it. I also tried additonal 1000u at the bridges, but there was no doubt it sounded worse.
Mad_K
Inductance and capacitance.
Check out http://www.diyaudio.com/forums/show...gh+speed+diodes
for some light reading ;)
mothman
Peter,
I want to try the local 4.7 caps at the rectifiers.Are you using them directly accross the DC legs of each bridge?
Thanks,
Bob
Peter Daniel
Yes
Page generated in 0.038678884506226 seconds with 17 queries,
spending 0.00786734 doing MySQL queries and 0.03081155 doing PHP things.
