| Drivetime |
| Hey, I'm getting ready to install some 6x9 speakers. I need some boxes built and I was wondering if there was a specific amount of volume I need for each speaker. |
| Drivetime |
| Really Bill? I couldn't have figured that out. Now either you're really cocky or you don't know anything. So if you do know what volume I need then you could be helpful and tell me. If not, try to find someone eles who uses this board for something other than what it was meant for. Thank You. |
| planet10 |
Every speaker will want to see a different volume....
dave |
| pinkmouse |
| If your driver manufacturer doesn't give you an ideal volume, you will need to measure the response curve. Do a search in the Loudspeakers thread for loudspeaker testing, there's loads of relevent stuff. ;) |
| planet10 |
| quote: | Originally posted by Drivetime
Really Bill? |
Don't mind Bill... sometimes he comes off as a cranky old guy, but he is quite knowledgable and we love him.
What kind of speakers are they? Brand, model? Any specs at all?
Car speakers usually don't come with specs, and if you can't measure them there are some approaches to cabinet building, which thou they may not be optimum, will give you a good shot under limited circumstances.
dave |
| Drivetime |
| They're Pioneer TS-A6963 6x9 3way speakers. I checked the box and it dosen't give an optimum volume. I was gonna do some searching on the net and with some audio stores around here but if you know what volume i need, that'd be great. |
| Bill Fitzpatrick |
Well excuse me!
If you already knew the answer to your own question why did you ask it in the first place? |
| planet10 |
They're Pioneer TS-A6963 6x9 3way speakers. |
Generally these are designed to sit in the back deck & have the trunk as a box so they like a big box. Bigger than you are likely to be able to build & live with.
So my recipe would be: 1/ build as large a box as you can get away with. 2/ drill a number of small closely spaced hole (with a total area of say a third the Sd of the speaker. Damp these "ports" with some compressed fiberglass insulation. The fancy way to do it is to rebate the area where the holes are (say 3/8" if you are using 3/4" material). Then take some fiberglass (as per the example 2" thick), compress it into the rebate, and hold it down with some of the plastic eaves-trough mesh. (This works best if the holes are in a long narrow configuration). Tuning is by increasing or decreasing the damping or the total area of the holes.
What is happening is that by putting the speaker into too small a box, you get a high Q response... the damped port then tries to lower the Q.
dave |
| planet10 |
| quote: | Originally posted by Bill Fitzpatrick
Bill... you have to take the question a little less literally... what he is really asking is "how do i figure the ideal box volume for a specific speaker"
dave |
| SkinnyBoy |
| BAHH!! 6X9's :p ditch them and get a pair of nice 6.5inch woofers and some tweeters... build some ported boxes and enjoy the cabin gain.. :D hehe (much easier to design boxes when you know the drivers specs) 6X9s have tweeters inbuilt.... and most often the speaker cone is used as a funel to direct dust down into the voice coil... ;) hehe its too early... :p |
| planet10 |
| quote: | Originally posted by SkinnyBoy
BAHH!! 6X9's :p ditch them |
Don't write them all off skinny boy... i'm no big fan of the co-ax or tri-ax, but some of the whizzer cone ones are VERY good... there is a particular delco 6x9...
dave |
| Bill Fitzpatrick |
| quote: | Originally posted by planet10
dave |
Yea, well I can't do my mind reading routine over the net. |
| SkinnyBoy |
Hey.. I woulda given the same answer as you.. ;) |
| Bill Fitzpatrick |
Well, gee then, maybe I can.
Hey, another post for me. When one hits 1K is there a prize? |
| SkinnyBoy |
nope... lol no prize... :( |
| Mantronic |
I did some 6"x9" box, large one...
I did them baout 1 cubic feet each...
Even scealed i have a lot of bass...
The reality is that the volume won't change a lot of thing... It's doesn't need to be very very specific...
Larger box = more bass
smaller box = less bass!!!
You can allway try to port :rolleyes:
Seriously it would be possible and you should go 1 cubic feet per speaker to 1 1/2 feet
and port about 5hz more that the lower the speaker goes...
The best you can do...
my 2 cents |
| phreeky82 |
6x9s are just made to use the whole trunk (or 'boot' for us aussies :) ) in most cases, as stated. and really it's probably gonna be best like that.
are you exceptionally concerned with sound from the rear, or is mainly just gonna be on quiet to keep the rear passengers happy when you rarely have them etc?
to me the idea of throwing 6x9s in the rear shelf was an easy way of getting a bit of bass for the time being (until i could afford a sub), and to get some sound in the rear. i'd be more concerned with fronts, and fade the sound to the front. |
| MearCat |
I have the same problem with a pair of 6.5" speakers in the front of my car. It's a 1971 Mini and my only option was to make a couple of boxes that screwed to the underside of the dash. You're VERY limited with room in the car so the boxes only ended up being 0.15 cu ft. I know it's tiny tiny tiny but they sound okay (for now) but want some more bass and I think porting is the only answer.
Planet10 - You mentioned that to lower the Q response you can drill a series of holes in the box, but I didn't understand how many holes (what is a "area of a third of the Sd of a speaker"??) you should drill and cover/dampen to test the speaker response.
-MearCat |
| phreeky82 |
Sd is the cone area.
I guess it's effectively using lots of tiny ports, but leaving them open as such, but using a soft material to dampen. the dampening will get rid of air flow noise (port noise) through these holes, and also not let the ports flow as much. that's how i understand it, but i may be wrong. |
| planet10 |
| quote: | Originally posted by MearCat
Sd is the piston area of the driver you are using. A 3rd is a ballpark number from my experience. Aperiodic enclosures are still very much a cut & try experience. After the port-lets are made, you then want to damp them by covering them with some resistance, i find compressed fiberglass works well. Sometimes the resistance of the small holes by themselves is enuff -- you have to play.
I just came up from a bit of a listen to some Ampex 517 cabinets that i loaded some accordian surround whizzer cone 6x9s (from out of a Dodge) into (the original drivers were dead). There is something about a FR oval that is really sweet...
dave |
