diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
degreasing perforated aluminum - Click HERE for Original Thread
wrl
Does anyone know a good way to degrease aluminum. My panels are large (54" X 15") if this makes a difference.]
Thanks,
Wes
Bill Fitzpatrick
Take them to a self service car wash?
ashok
Maybe you can use TCE . Tetra Chloro Ethylene.
SY
Use rags dipped in methyl ethyl ketone (MEK). Work in a WELL ventilated area, and away from any sources of sparks or flames (like pilot lights or motors)- MEK is highly flammable and highly volatile.
mwmkravchenko
car wash them first. Bill's right.
Try a good scrub with baking soda it works!
I use a water and baking soda paste to clean my sawblades and I've used it as a parts cleaner too.
If you have to go the chemical route STP makes a great degreaser
just don't leave it on to long.
Mark
Peter Daniel
Buy a spray degreaser from Auto-Parts store, used for car engine clean up. Take panels to self serve car wash, spray with degreaser, wait 10 min or so and rinse with water. ;)
Da5id4Vz
I used to buy 55-gallon drums of 111 triclorofloroethane from a company called Safety Kleen. My use was for cleaning motion picture films. Most of there customers used Safety Kleen brand parts washers for grease removal. You might try contacting them and finding out who in your area has a machine large enough to handle your needs.
http://www.safety-kleen.com/skcda/v...nnel/SKhome.jsp
SY
IIRC, that stuff is very restricted these days, due to the linking of it with holes in the ozone layer. Too bad, it's an effective solvent. MEK, though flammable, is still the standard solvent used to prep surfaces for finishing. Cuts grease, dries quickly, leaves surfaces clean enough to be anodized, which an aqueous wash won't. And you can get it cheep at any Home Despot.
Da5id4Vz
Most good solvents are restricted these days. Ironically percloriform, dry cleaning fluid, is over 100x as bad an ozone depleter as methelclorform, and yet we don’t ban it. The dry cleaning association apparently has a pretty good political lobby.
One of the things I liked about Safety Kleen is that they managed my waste and helped with the regulatory requirements too. I understand that price and availability has almost completely eliminated the use of these solvents in motion picture film handling.
Peter Daniel
quote:
Under what name? I don't remember seeing it locally.
Sch3mat1c
I've seen gallon cans of MEK (along with many other solvents) at the hardware store (Ace) for like $5 or 10.
Tim (has a half gallon of 111TCE :D )
wrl
Thanks guys, I'll probably go with the auto degreaser and the car wash route. I am a little hesitant to use harsh chemicals. Funny although I work in a chem lab. (I guess no need to expose myself unnecesarily)
Thanks,
Wes
joan2
lye solution, is good cleaning agent for aluminum, read from the radio amatuer's handbook, it is discussed there,, if your aluminum is collored you can not use this however, do this is a well ventillated area...
SY
Lye is a good prep for anodizing, BUT... it is truly nasty stuff. It will literally turn you to soap. Use eye protection, wear rubber gloves, and a rubber apron is not a bad idea.
Bricolo
I use white spirit
purplepeople
Try lighter fluid. Excellent solvent - you'll need very little and the excess evaporates very quickly. If the grease is particularly bad, start with a little gasoline, then the lighter fluid. Used this to clean off small lacquer and enamel mistakes in a small paint shop.
If you are squeamish about using VOCs, then put the panels in your shower, get some dishwashing liquid (for hand washing - not the machine wash stuff) and spread it all over as evenly as you can, then let it sit for a while. Then rinse off. Just like aluminum cookware.
If you need some more scrubbing power, use Tide laundry powder. My mechanic taught me this one. Better than any of the automotive stuff for cleaning hands after a hard day's work.
:)ensen.
roddyama
OK, I want all your names and addresses.
Jocko Homo
Not for degreasing. Taking off burrs, rough edges and the like, then yes.
Making a nice etched surface and leaving a lot of gray gunk in the bottom of the vat, then also yes.
This also applies to any "detergent" high in phosphates. May be harder to find these days thanks to people like........uh, I better quit while I am ahead.....
So........Rodd is turning into the "Central Scrutinizer" in his new role as moderator, eh?
Jocko
grimberg
Rodd makes a very good point. I can't understand why everyone is aiming for harsh chemicals. If the "grease" in this case is just oil used for cutting and tapping, dishwashing liquid applied with a soft sponge does the job nicely. If the greasy spots are stubborn, you can use Simple Green detergent (http://www.elgene.com/SimpleGreenD.html), available in the US at Target, K-Mart, WalMart, Home Depot and other places.
grataku
From my organic chemistry days (well years actually):
My list of best cleaning in the world by application:
ethyl ether (light grease)
hexanes/xylene (heavy grease)
methylene chloride (solder flux)
ethyl acetate (solvent based glues)
acetone and methyl ethyl ketone (general soil and other **** not particulary good on grease and cutting oils)
ethanol (200 proof) no residue/methanol same as acetone but leaves no residue.
:att'n: :att'n:
All these solvents are extremely flammable, toxic (yes even our friend ethanol), and environmentally unfriendly.
:att'n: :att'n:
When I worked in a machine shop I used concentrated orange cleaner, it works very well but it always requires some brushing or scotch brite action. For cleaning inaccessible places like tapped holes and things of the sort a little solvent works wonders.
Jocko Homo
Or Formula 409.
Read the August 2003 issue of Aviation Consumer to find out why. (Don't ask me where to find it...........)
I don't want to have to 'splain this again.
Besides, perforated metal is too damn expensive to ruin that way.
Jocko
grataku
quote:
Originally posted by Jocko Homo
Or Formula 409.
Yes, many high power detergents are alkaline and if left on the metal for too long they will etch it.
Peter Daniel
It is amazing how such a simple matter, become so complicated;)
grimberg
Jocko,
I found their web site but they want $12.95 for the article.
http://www.aviationconsumer.com/pub...ers/5267-1.html
However, on the headline they give enough information to select a product:
"...Crazy Clean was a surprise winner."
Jocko Homo
I read about it in the CAP newsletter. I don't have the entire article, just excerpts buried under several layers of e-mail attachments.
mrfeedback
Scrubbing with standard green dishwashing detergent and then laundry cloudy ammonia, rinsing with high pressure hose, and then blast dry with compressed air does the job perfectly.
Also good for getting tannin stains out of teacups and getting wineglasses crystal clean.
Eric.
wrl
Wow, I never expected this many replies. Thanks guys.
FYI, I ended up purchasing a commercial degreasing product from Lowes. (I don't remember the brand name) and taking it to a diy carwash. Those things are a ripoff man. 10 dollars for about 10 minutes of water.
Oh well, the combination of the degreaser and the hi-pressure H20 did the trick quite well. :)
Thanks,
Wes
Page generated in 0.053613901138306 seconds with 17 queries,
spending 0.00789738 doing MySQL queries and 0.04571652 doing PHP things.
